@EWOK4LIFE wrote:
JUST ENTER "%%U" IN THE FRONT OF YOUR FIRST LETTER.
[Ten-year-old thread, but nevertheless, for the sake of others Searching for this kind of question....]
That's not a solution:
1) It won't work for Mtext [see the original request in Post 1], at least in newer versions [I think %%U was the underlining toggle also inside Mtext in old-enough versions, but I'm not sure how far back].
2) It will only remove underlining [see the Subject line] if the Text is underlined from the beginning and for its entire length. If it's partially underlined, the places where the switchover occurs will change to switch in the opposite direction, but there will still be underlining:
3) If there is currently no underlining, it will add underlining to the whole thing, the opposite of the original request.
If it might help, here is the original @Unformat function from 2003:
(@Unformat ename "L") or (@Unformat Object "L") will hopefully work for you.
The Formats argument is NOT case-sensitive.
(defun @UnFormat (Mtext Formats / All Format1 Format2 Text Str) ;;-------------------------------------------------- ;; Primary function to perform the format stripping: ;; (04-20-03) John F. Uhden, Cadlantic ;; Arguments: ;; Mtext - the Mtext VLA-Object or Ename ;; Formats - a string containing some or all of the following characters: ;; A - Alignment ;; C - Color ;; F - Font ;; H - Height ;; L - Underscore ;; O - Overscore ;; P - Linefeed (Paragraph) ;; Q - Obliquing ;; S - Spacing (Stacking) ;; T - Tracking ;; W - Width ;; ~ - Non-breaking Space ;; Optional Formats - ;; * - All formats ;; Returns: ;; nil - if not a valid Mtext object ;; Text - the Mtext textstring with none, some, or all ;; of the formatting removed, depending on what ;; formats were present and what formats were ;; specified for removal. ;; (cond ((= (type Mtext) 'VLA-Object)) ((= (type Mtext) 'ENAME) (setq Mtext (vlax-ename->vla-object Mtext)) ) (1 (setq Mtext nil)) ) (and Mtext (= (vlax-get Mtext 'ObjectName) "AcDbMText") (= (type Formats) 'STR) (setq Formats (strcase Formats)) (setq Mtext (vlax-get Mtext 'TextString)) (setq Text "") (setq All T) (if (= Formats "*") (setq Formats "S" Format1 "\\[LOP`~]" Format2 "\\[ACFHQTW]" ) (progn (setq Format1 "" Format2 "") (foreach item '("L" "O" "P" "~") (if (vl-string-search item Formats) (setq Format1 (strcat Format1 "`" item)) (setq All nil) ) ) (if (= Format1 "") (setq Format1 nil) (setq Format1 (strcat "\\[" Format1 "]")) ) (foreach item '("A" "C" "F" "H" "Q" "T" "W") (if (vl-string-search item Formats) (setq Format2 (strcat Format2 item)) (setq All nil) ) ) (if (= Format2 "") (setq Format2 nil) (setq Format2 (strcat "\\[" Format2 "]")) ) T ) ) (while (/= Mtext "") (cond ((wcmatch (strcase (setq Str (substr Mtext 1 2))) "\\[\\{}]") (setq Mtext (substr Mtext 3) Text (strcat Text Str) ) ) ((and All (wcmatch (substr Mtext 1 1) "[{}]")) (setq Mtext (substr Mtext 2)) ) ((and Format1 (wcmatch (strcase (substr Mtext 1 2)) Format1)) (setq Mtext (substr Mtext 3)) ) ((and Format2 (wcmatch (strcase (substr Mtext 1 2)) Format2)) (setq Mtext (substr Mtext (+ 2 (vl-string-search ";" Mtext)))) ) ((and (vl-string-search "S" Formats)(wcmatch (strcase (substr Mtext 1 2)) "\\S")) (setq Str (substr Mtext 3 (- (vl-string-search ";" Mtext) 2)) Text (strcat Text (vl-string-translate "#^\\" " " Str)) Mtext (substr Mtext (+ 4 (strlen Str))) ) ) (1 (setq Text (strcat Text (substr Mtext 1 1)) Mtext (substr Mtext 2) ) ) ) ) ) Text )
John F. Uhden
I wrote one a while back that works for TEXT and MTEXT entities.
It toggles the removal and addition of the underline.
Let me know if it helps 🙂
~Z
