Visual LISP, AutoLISP and General Customization
Remove Number once from sheet set manager instead of one by one
1 REPLY 1
shehab10
449 Views, 1 Reply
Hello, I am thinking of a possible lisp routine that can remove numbers inserted by Autocad inside sheet set manager.
I knew that you can remove numbers by clicking on the sheet and click Rename& Renumber Sheet and then empty it -- next.
But this is a tedious step if you have above 50 or 100 sheets. So I want to shortcut the steps by a lisp that can do that automatically instead of manual executions.
I attached image explaining what i mean.
I think that will be very useful because we number inside layout and then we put symbol and collecting from All desciplines(str,mech,electrical,..) to produce a pdf in order but that automatic autocad number is hindering us.
Please help,
Cheers,
1 REPLY 1
hmsilva
in reply to: shehab10
Hi shehab,
unfortunately you can't acess sheet set manager using AutoLISP/Visual LISP...
You'll need to use other programming language, such as VBA, .NET... to acess sheet set manager...
Henrique
”Boost
