Hi all,
I searched around for this answer before asking here and I'm only finding information stating that -overkill command is supposed to remove duplicate dimension entities but my tests show different. -overkill NEVER removes duplicate dimensions. the dimensions are being placed on top of each other and simply bloat the drawing file. Can anyone provide advice or do you know of a lisp that will simply remove duplicate Aligned Dimensions?
Thank you.
Your dimensions are most likely associative. If you uncheck the "maintain associative objects" box, then the overkill should work correctly.
