Relative Xefs - Routine Adjustment
3 REPLIES 3
Hugh_Compton
364 Views, 3 Replies
I've been using a brilliant lisp by someone called Mark McDonough that looks at each XRef in an open DWG and converts them into Relative Path XRefs.
This works very well but I am using it in the middle of a VB.Net routine and the 'pause' that requires a press of the Enter key / spacebar key is causing me to stumble.
Could some kind soul remove the command line pause so that the routine runs from start to finish without stopping for an Enter / Spacebar?
3 REPLIES 3
stevor
in reply to: Hugh_Compton
Try commenting out the grread; eg: ; (grread)
S
stevor
in reply to: stevor
In addition to the grread, the 'alert' at...
(alert "This version of XRP is designed for AutoCAD R14 - 2005 only")....
will 'pause' the execution, if the autocad in not in this program's agenda...
For such case, you could try commenting that line out but test the results.
S
Hugh_Compton
in reply to: stevor
Brilliant, there was one occurance of the "grread", commenting this out has done the trick.
Hugh
”Boost
