Visual LISP, AutoLISP and General Customization
Read second column from a CSV
5 REPLIES 5
CAD-a-Mia
837 Views, 5 Replies
If I have a CSV file (with no header) that contains three columns and I want to return values of  the second column as a list, how is the best method to do that?
I have seen something where one can separate a string into a list by a divider (in my case, the commas between the three columns) but the actual code for me to inspect was supposed to be in an attached ZIP file which I didn't see as part of the post.
An example of my CSV (as a list) wouild be:
("PO-30-10,PIN OAK,88-15" "PO-30-10,PIN OAK,88-01A" "JS-20-5,JUNIPER,63-04" "PP-40-10,POPLAR,38-22")
and I need the resulting list to be:
("PIN OAK" "PIN OAK" JUNIPER" "POPLAR")
Is there a LISP way to do this - or only VLISP?
                                      ~Mia
5 REPLIES 5
southie
in reply to: CAD-a-Mia
Mia
Here ia a way.
(setq xx '("PO-30-10,PIN OAK,88-15" "PO-30-10,PIN OAK,88-01A" "JS-20-5,JUNIPER,63-04" "PP-40-10,POPLAR,38-22"))
(foreach n xx
(setq a (vl-string-position (ascii ",") n))
(setq b (substr n (+ a 2)))
(setq c (vl-string-position (ascii ",") b))
(setq d (substr b 1 c))
(setq vv (append vv (list d)))
("PIN OAK" "PIN OAK" "JUNIPER" "POPLAR")
hth
pbejse
HYG
(defun second (str / func str)
  (setq func (lambda (j) (substr j 1 (vl-string-position 44 j)))
        str (substr str (+ (strlen (func str)) 2))
	str (func str)
 (mapcar 'second '("PO-30-10,PIN OAK,88-15" "PO-30-10,PIN OAK,88-01A" "JS-20-5,JUNIPER,63-04" "PP-40-10,POPLAR,38-22"))
Perhaps it would be better if you stripped the string right after the read-line
(while (Setq x (read-line fl))
(setq lst (cons (second x) lst))
Do you really need a vanilla version of the code?
pbejse
in reply to: pbejse
A Generic code  (Vanilla)
(defun secondV (j n / x a b c i)
 (setq a "" b (lambda ()(substr j 2)) i 0)
        (while (and (wcmatch j "*`,*")
		    (setq x (ascii j))
		    (> n i))
	    (if (eq x 44)
	      	(setq c a a "" j (b) i (1+ i))
		(setq a (strcat a (chr x))
		      j (b))))
	       (if (> n i) j c ))
(Setq a "JS-20-5,JUNIPER,63-04")
(secondV a 1)
hth"JS-20-5"
(secondV a 2)
"JUNIPER"
(secondV a 3)
"63-04"
(setq lst '("PO-30-10,PIN OAK,88-15" "PO-30-10,PIN OAK,88-01A" "JS-20-5,JUNIPER,63-04" "PP-40-10,POPLAR,38-22"))
(mapcar '(lambda (r)(secondV r 1)) lst)
("PO-30-10" "PO-30-10" "JS-20-5" "PP-40-10")
(mapcar '(lambda (r)(secondV r 2)) lst)
(mapcar '(lambda (r)(secondV r 3)) lst)
("88-15" "88-01A" "63-04" "38-22")
HTH
martti.halminen
(defun csv-second-column (path separator)
  ;; produces a list of the items in the second column of a csv file. Separator as a single-character string.
  (mapcar '(lambda (line)
            (cadr (split-string line separator)))
          (file-to-list path)))
(defun split-string (str delim / pos)
  ;; Splits a string into a list of strings at every occurrence of the delim (single-letter string).
  (setq pos (vl-string-position (ascii delim) str))
  (if (null pos)
      (list str)
      (cons (substr str 1 pos)
            (split-string (substr str (+ pos 2)) delim))))
(defun file-to-list (filename / file result line)
  (if (findfile filename)
      (progn (setq file (open filename "r"))
             (while (setq line (read-line file))
               (setq result (cons line result)))
             (close file)
             (reverse result))
      (alert (strcat "File " filename " not found!"))))
pbejse
in reply to: martti.halminen
FWIW: VL code for  delimiter separator
(defun _delFinder  (str md / d l str)
      (while (setq d (vl-string-position md str nil T))
            (setq l (cons (substr str (+ 2 d)) l)
                  str (substr str 1 d)))
      (cons str l)
HTH
”Boost
