Hi All,
I'm trying to get an excel sheet to open and count cells based on the text inside a selected column then compare it to cad.
the column says "red" or "green" and I want to compare it to a count of red and green hatches in cad.
I managed to get them to be counted in cad but I'm not sure how to get the excel part to work
Note: I posted an earlier post thinking to count the actauly colour in the excel cells rather than the words but that ended up being quite complicated.
Any help would be greatly appreciated
Solved by Hallex. Go to Solution.
Try this code, make sure you renamed Excel sheet name and column address
within the code
(defun C:XLCR (/ *error* GetXlRangeByMatch address filename sheetname x xlapp xlbook xldata xlrange) (vl-load-com) (defun *error* (msg) (if xlbook (vl-catch-all-apply 'vlax-invoke-method (list xlbook 'Close :vlax-false))) (gc) (if xlapp (vl-catch-all-apply 'vlax-invoke-method (list xlapp 'Quit))) (gc) (cond ((not msg)) ((member msg '("Function cancelled" "quit / exit abort"))) ((princ (strcat "\n** Error: " msg " ** ")))) (princ) ) (defun GetXlRangeByAddress(filename sheetname address / xlbook xlrange xlsheet xlapp skv_records) (setq xlapp(vlax-get-or-create-object "Excel.Application")) (vla-put-visible xlapp :vlax-true) (vlax-put-property xlapp 'DisplayAlerts :vlax-false) (if (zerop (vlax-get-property(vlax-get-property xlapp 'workbooks) 'count)) (setq xlbook (vl-catch-all-apply 'vla-open (list (vlax-get-property xlapp 'WorkBooks) fileName)) ) (setq xlbook (vl-catch-all-apply 'vlax-get-property (list xlapp 'activeworkbook)))) ;;__________________________________________________________________________________;; (if (numberp sheetname) (setq xlsheet (vl-catch-all-apply 'vlax-get-property (list (vlax-get-property xlbook 'Sheets) 'Item sheetname ;|"Sheet1" or 1 maybe|;;< --- sheet name or number ) ) ) (progn (vlax-for sht (vlax-get-property xlbook 'Sheets) (if (eq (vlax-get-property sht 'Name) sheetname) (setq xlsheet sht))))) ;;_____________________________________________________________________________________;; (vlax-invoke-method xlsheet 'Activate) (setq xlrange (vlax-get-property (vlax-get-property xlsheet 'Cells) 'Range address)) (if (eq :vlax-true (vlax-variant-value(vlax-get-property xlrange 'HasFormula))) (setq xldata (vlax-get-property xlrange 'formulalocal)) (setq xldata(vlax-get-property xlrange 'value2))) (setq xldata (mapcar '(lambda(x) (mapcar 'vlax-variant-value x)) (vlax-safearray->list (vlax-variant-value xldata))) ) (if (eq 1(length (car xldata))) (setq xldata (vl-remove-if 'not(mapcar 'car xldata))) (setq xldata (vl-remove-if 'not xldata))) (vl-catch-all-apply 'vlax-invoke-method (list xlbook 'close :vlax-false)) (vlax-put-property xlapp 'DisplayAlerts :vlax-true) (gc);; before QUIT (vl-catch-all-apply 'vlax-invoke-method (list xlapp 'quit)) (mapcar '(lambda(x)(if (and x (not (vlax-object-released-p x))) (progn(vlax-release-object x)(setq x nil)))) (list xlrange xlsheet xlbook xlapp)) (gc);; after QUIT xldata ) ;;___________________________ main part _______________________;; ;; e.g.: (setq filename (getfiled "Select Excel file : " "Dpipke"; (getvar "dwgprefix") "xlsx;xls" 4 ) sheetname "Sheet1" address "B1:B1000");<-- also you're could to put exact address , say B10:B23 etc (setq xlData (GetXlRangeByAddress filename sheetname address)) (alert (strcat "Return column data:\n\n"(vl-princ-to-string xlData) "\n\nrest your mojo in acad is goes here.")) ;;; --- rest your mojo with acad is goes here --- ;;; (*error* nil) (princ) ) (princ "\n\t\t---\tStart command with XLCR\t---") (prin1) (or (vl-load-com)(princ))
;;; If you need some more help with this so let me know about
Thanks for the help. This is a little above me so I'm not sure exactly whats going on. Is it putting the column data into a string? I know when I run it it returns an alert with the data content of the cells. Does Lisp have an equivalent of a string count function? So count the number of time "red" and "green" appears in the string then store it into variables?
I've added function to count elements in column,
Do your rest work by yourself:
(defun C:XLCR (/ *error* GetXlRangeByMatch address filename gruppen sheetname x xlapp xlbook xldata xlrange) (vl-load-com) (defun *error* (msg) (if xlbook (vl-catch-all-apply 'vlax-invoke-method (list xlbook 'Close :vlax-false))) (gc) (if xlapp (vl-catch-all-apply 'vlax-invoke-method (list xlapp 'Quit))) (gc) (cond ((not msg)) ((member msg '("Function cancelled" "quit / exit abort"))) ((princ (strcat "\n** Error: " msg " ** ")))) (princ) ) (defun GetXlRangeByAddress(filename sheetname address / xlbook xlrange xlsheet xlapp skv_records) (setq xlapp(vlax-get-or-create-object "Excel.Application")) (vla-put-visible xlapp :vlax-true) (vlax-put-property xlapp 'DisplayAlerts :vlax-false) (if (zerop (vlax-get-property(vlax-get-property xlapp 'workbooks) 'count)) (setq xlbook (vl-catch-all-apply 'vla-open (list (vlax-get-property xlapp 'WorkBooks) fileName)) ) (setq xlbook (vl-catch-all-apply 'vlax-get-property (list xlapp 'activeworkbook)))) ;;__________________________________________________________________________________;; (if (numberp sheetname) (setq xlsheet (vl-catch-all-apply 'vlax-get-property (list (vlax-get-property xlbook 'Sheets) 'Item sheetname ;|"Sheet1" or 1 maybe|;;< --- sheet name or number ) ) ) (progn (vlax-for sht (vlax-get-property xlbook 'Sheets) (if (eq (vlax-get-property sht 'Name) sheetname) (setq xlsheet sht))))) ;;_____________________________________________________________________________________;; (vlax-invoke-method xlsheet 'Activate) (setq xlrange (vlax-get-property (vlax-get-property xlsheet 'Cells) 'Range address)) (if (eq :vlax-true (vlax-variant-value(vlax-get-property xlrange 'HasFormula))) (setq xldata (vlax-get-property xlrange 'formulalocal)) (setq xldata(vlax-get-property xlrange 'value2))) (setq xldata (mapcar '(lambda(x) (mapcar 'vlax-variant-value x)) (vlax-safearray->list (vlax-variant-value xldata))) ) (if (eq 1(length (car xldata))) (setq xldata (vl-remove-if 'not(mapcar 'car xldata))) (setq xldata (vl-remove-if 'not xldata))) (vl-catch-all-apply 'vlax-invoke-method (list xlbook 'close :vlax-false)) (vlax-put-property xlapp 'DisplayAlerts :vlax-true) (gc);; before QUIT (vl-catch-all-apply 'vlax-invoke-method (list xlapp 'quit)) (mapcar '(lambda(x)(if (and x (not (vlax-object-released-p x))) (progn(vlax-release-object x)(setq x nil)))) (list xlrange xlsheet xlbook xlapp)) (gc);; after QUIT xldata ) ;; group with sum elements in list ;; fixo () 2006 * all rights released (defun suminlist (lst) (if (car lst) (cons (cons (car lst) (length (vl-remove-if-not '(lambda (x) (equal (car lst) x 0.001)) lst) ) ) (suminlist (vl-remove-if '(lambda (x) (equal (car lst) x 0.001)) lst) ) ) ) ) ;;___________________________ main part _______________________;; ;; e.g.: (setq filename (getfiled "Select Excel file : " "Dpipke"; (getvar "dwgprefix") "xlsx;xls" 4 ) sheetname "Sheet1" address "B1:B1000");<-- also you're could to put exact address , say B10:B23 etc (setq xlData (GetXlRangeByAddress filename sheetname address)) ;;; --- rest your mojo with acad is goes here --- ;;; (setq gruppen (suminlist xldata)) (alert (strcat "Return column data with count:\n"(vl-princ-to-string gruppen))) (*error* nil) (princ) ) (princ "\n\t\t---\tStart command with XLCR\t---") (prin1) (or (vl-load-com)(princ))
