Valued Contributor
FT398
Message 11 of 14 (181 Views)
Re: Reactor triggers fatal error
06-18-2012 07:34 AM in reply to: FT398
Found it.
It seems that the error is triggered by the use of command-s within the routines error handlers.
A search tells me that command-s appears in these files so presumably they will all be affected.
MVSETUP.lsp
EDGE.lsp
AI_UTILS.lsp
VL.arx
Distinguished Mentor
Moshe-A
Message 12 of 14 (163 Views)
06-18-2012 10:01 PM in reply to: FT398
You mean they use (command) function?
i do not thing they made so essential changes to these command from previous releases
moshe
Valued Contributor
FT398
Message 13 of 14 (159 Views)
06-18-2012 10:33 PM in reply to: FT398
It seems that command-s was introduced in AutoCAD 2012. The MVSETUP and EDGE lisp routines which shipped with 2011 and earlier use 'command' and these versions do not trigger the fatal error. However, the use of command-s on 2012 and 2103 when a CommandWillStart reactor is loaded will trigger a fatal error.
Partial  error routine from Edge.lsp (2011)
(defun edge-er (n)
  (if (/= s "Function cancelled")
    (princ (strcat "\nError: " n))
  (command)
  (command "_.UCS" "_P")
Same section from Edge.lsp (2013)
(defun edge-er (n)
  (setq *error* lisp-er)
  (edge_setCmdEcho 0)
  (command-s "_.UCS" "_P")
If you are running 2012/2013 then load the reactor from my original post and then use this command and you will get a fatal error:
(command-s "_.line" "0,0,0" "10,10,0" "")
Valued Mentor
Ian_Bryant
Message 14 of 14 (142 Views)
06-19-2012 04:41 AM in reply to: FT398
Yes you are right, using the command-s function causes Autocad to crash,
when a command reactor is loaded.
I eventually found a description of this function in 2013 help.
It says that the function runs in a temporary command processor
separate from the main Autocad command processor,
and gives an example of how improper use might crash Autocad.
- using (command-s "U") while an ordinary command is active.
It would appear that they forgot to consider how the function
would handle command reactors.
Ian
