I am trying to find a way to make a reactor respond to making a sheet set current by any means. I want to identify the current Sheet Set and at first I thought what I needed was SSFOUND but that variable is associated with the current drawing and not the current Sheet Set. I have a command based method to set the default plot to file path based on the current drawing path but I would rather automate it based on any activity that makes a sheet set current. Since I use [Sheet Set item right-click menu>Publish>Publish using Page Setup Override] almost exclusively I need the default plot to file path to be matched to the current sheet set at all times. I see in the VBAIDE the class "AcSmEvent" and the member "ACSM_DATABASE_LOAD_COMPLETE" but I have no experience with VBA.
Would these be useful in constructing the reactor I want?
Is the member identified only indicating the last loaded sheet set and not the current sheet set (e.g., a switch between sheet sets happened after the last loaded sheet set)?
Is there a VLisp method to get at the current sheet set?
---------------------------------------------Signature--------------------------------------------
Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
Windows 10 Pro 64-bit Intel﴾R﴿ Core﴾TM﴿ i9-12900KF CPU 3.19GHz; 32 GB DDR4 4266 Dual Channel RAM
nVidia Quadro RTX 4000; AutoCAD Civil 3D 2023.2.1 Update
