Reactor for polyline creation, deletion, or copy?
6 REPLIES 6
278 Views, 6 Replies
I have never created a reactor function.
I would like tips to help me create a reactor function that notifies me (say
an alert message) if any of the following events happen:
a polyline (heavy or light) is created, is deleted, or is copied.
Len
To email reply, eradicate all threes in my SPAM guarded address.
6 REPLIES 6
A concern of mine is the bad reputation reactors have according to some
who've posted here. I certainly don't want to open some pandora's box.
But here is a snippet I've created by modifying some existing code I found
online. By the way, the drawings I'm creating this for contain nothing but
polylines, therefore the simplicity. Do you see any problems?
(defun cmdEND (reactor command_l)
(if (or
(member "PLINE" command_l)
(member "COPY" command_l)
(member "ERASE" command_l)
(alert "\n A polyline was drawn, copied, or erased.")
(defun c:reactorPline ()
(vl-load-com)
(vlr-editor-reactor nil '((:vlr-commandEnded . cmdEND)))
(c:reactorPline)
"Fatfreek" wrote in message
news:5434699@discussion.autodesk.com...
Len
EC-CAD
Fatfreek,
IF Moved, doesn't fire.
IF Polyline is from Entmake.. doesn't fire.
IF object Erased or Copied is *not* a PLINE.. fires
when it should *not* fire.
Other than that, seems to work.
Bob
Thanks for that tip. I'll add MOVE and SCALE. I'll try to add Entmake but
will have to figure that out.
Len
wrote in message news:5434687@discussion.autodesk.com...
Fatfreek,
Bob
Hmmm ... I see that each different command that I use dictates the
occurrences that the alert box pops up. How can I reset the counter back to
zero?
Len
Fatfreek,
Bob
EC-CAD
Close, re-open the drawing ?
As far as 'counter' .. I don't think there is one..
You might want to add "EXPLODE" to the list..
Bob
Yes, I will add "EXPLODE", thank you.
I was wrong about the cause of the instances.
The cause appears to coincide with the number of times I've edited and
reloaded the function.
Len
wrote in message news:5434748@discussion.autodesk.com...
Bob
”Boost
