Valued Contributor
bodhran
Message 1 of 7 (290 Views)
RE-size Viewports across Multiple Layouts
290 Views, 6 Replies
06-25-2012 03:19 PM
Just wondering if any one has a routine to re-size viewports in multiple layouta??
We have to re-size viewports as they were created a little too small and are now spread across almost 1000 drawings in 18 dwg.
B
pbejse
Message 2 of 7 (280 Views)
Re: RE-size Viewports across Multiple Layouts
06-25-2012 09:47 PM in reply to: bodhran
B
Too smaill in terms of viewport scale? or the size of the viewport (L&W)?
Valued Contributor
bodhran
Message 3 of 7 (261 Views)
07-02-2012 04:21 PM in reply to: pbejse
Sorry for the late reply. It's the Length & Widht i'd like ot be able ot modify. Thanks, B
pbejse
Message 4 of 7 (252 Views)
07-02-2012 11:16 PM in reply to: bodhran
This demo would re-size the viewprot on all layout tabs by mulitplying the current viewprot size by a factor supplied by the user and keepingthe viewport scale intact
(Defun c:smileyvery-happy:emo1 ( / factor vps)
      (initget 1)
      (setq factor (getreal "\nEnter re-size factor: "))
       (setq vps (ssget "_X" '((0 . "Viewport") (-4 . "/=") (69 . 1))))
       (repeat (sslength vps)
                           (setq e (vlax-ename->vla-object (ssname vps 0)))
                           (setq cscale (vla-get-CustomScale e))
      (vlax-invoke e 'ScaleEntity (vlax-get e 'Center) factor)
      (vla-put-CustomScale e cscale)
                           (ssdel (ssname vps 0) vps)
      (princ)
This on the other hand will scale even the viewport scale by a factor supplied by the user
(Defun c:smileyvery-happy:emo2 ( / factor vps)
      (initget 1)
      (princ)
Now if you have a specific length and with in mind , you may want to supply "what is" and "what will" or just go ahead and assigned them  regardless of what was.
HTH
Valued Contributor
bodhran
Message 5 of 7 (230 Views)
07-10-2012 09:15 PM in reply to: pbejse
Exceelent work!!
Is it possible to change the horizontal size and vertical size?
even seperate routines would be good.
B
pbejse
Message 6 of 7 (216 Views)
07-11-2012 05:21 AM in reply to: bodhran
bodhran wrote:
Exceelent work!!
B
Is that Horizontal and/or Vertical? it can be done with one routine.
Notice the snippets i posted us a factor as multiplier, is that what you want? or a pre-determined Lenght and Width?
(WWAWW: what was and what will)
What about the viewport scale?
Valued Contributor
bodhran
Message 7 of 7 (206 Views)
07-12-2012 04:07 PM in reply to: pbejse
Hi there,
At the moment it's just a vertical re-sizing i need but if it isn't too much trouble to produce somethign that could re-size horizontal too i'd rally appreicate the help.
I'd like to keep the scale the same for all viewports, they were created to dispaly an output from 3rd party software, the guys producing the outputs had to exceed the limits they were gien in model space and now i'd like ot make the viewports taller but keep the current scale.
B
