Visual LISP, AutoLISP and General Customization
RE-size Viewports across Multiple Layouts
6 REPLIES 6
bodhran
708 Views, 6 Replies
Just wondering if any one has a routine to re-size viewports in multiple layouta??
We have to re-size viewports as they were created a little too small and are now spread across almost 1000 drawings in 18 dwg.
B
6 REPLIES 6
pbejse
in reply to: bodhran
B
Too smaill in terms of viewport scale? or the size of the viewport (L&W)?
bodhran
in reply to: pbejse
Sorry for the late reply. It's the Length & Widht i'd like ot be able ot modify. Thanks, B
pbejse
This demo would re-size the viewprot on all layout tabs by mulitplying the current viewprot size by a factor supplied by the user and keepingthe viewport scale intact
(Defun c:Demo1 ( / factor vps)
      (initget 1)
      (setq factor (getreal "\nEnter re-size factor: "))
       (setq vps (ssget "_X" '((0 . "Viewport") (-4 . "/=") (69 . 1))))
       (repeat (sslength vps)
                           (setq e (vlax-ename->vla-object (ssname vps 0)))
                           (setq cscale (vla-get-CustomScale e))
      (vlax-invoke e 'ScaleEntity (vlax-get e 'Center) factor)
      (vla-put-CustomScale e cscale)
                           (ssdel (ssname vps 0) vps)
      (princ)
This on the other hand will scale even the viewport scale by a factor supplied by the user
(Defun c:Demo2 ( / factor vps)
      (initget 1)
      (princ)
Now if you have a specific length and with in mind , you may want to supply "what is" and "what will" or just go ahead and assigned them  regardless of what was.
HTH
bodhran
in reply to: pbejse
Exceelent work!!
Is it possible to change the horizontal size and vertical size?
even seperate routines would be good.
B
pbejse
@bodhran wrote:
Exceelent work!!
B
Is that Horizontal and/or Vertical? it can be done with one routine.
Notice the snippets i posted us a factor as multiplier, is that what you want? or a pre-determined Lenght and Width?
(WWAWW: what was and what will)
What about the viewport scale?
bodhran
in reply to: pbejse
Hi there,
At the moment it's just a vertical re-sizing i need but if it isn't too much trouble to produce somethign that could re-size horizontal too i'd rally appreicate the help.
I'd like to keep the scale the same for all viewports, they were created to dispaly an output from 3rd party software, the guys producing the outputs had to exceed the limits they were gien in model space and now i'd like ot make the viewports taller but keep the current scale.
B
”Boost
