Visual LISP, AutoLISP and General Customization
re inserting a standard base template for layering?
2 REPLIES 2
255 Views, 2 Replies
i'm in two minds about creating a lisp or pulldown with some standard features in it.
what i would like to do is be able to quickly insert a template (layers/linetypes/colours etc) which is the same used in our initial drawing. I'm a big fan of constantly purging and auditing my drawings to keep them clean and in a previous workplace we had the ability to reinsert all the default layering.
I originally thought it was a block with all the layers in it, does anyone know if a simple lisp routine would be the way to go? if yes, how would i go about it?
2 REPLIES 2
Here is what I use. (see attached)
What I did is used one of my templates and removed all of the objects leaving the layers, dimstyles, text styles, etc..
It will insert the block & then delete & purge it.
Change the path & block name to suit your needs. Dont forget the name of the block in the purge line.
(LAD) Layers & Dimensions
Rick
scot-65
Our office has a similar problem to where inserting a block containing
the default text styles, linetypes, layers, and dimension styles seems
to work, but then again it does not:
Assigned line type and/or color of an existing layer will not align to the
block "template" you are inserting. Layer1 has a linetype of Dashdot.
Layer1 in the template has a linetype of Dashdotx2. The template will
not change the destination drawing's linetype or color.
In the destination file, textstyle is "H1" is assigned to something other
than "H1.shx", but it is shown as true in the template. The destination
file will retain the relationship of H1 /= H1.shx.
Dimension style will not realign either.
There are two solutions here:
1) Make your block as a DWT file extension and insert the
destination file into this DWT, then do a Save As.
2) Our solution is a custom purge which does everything except the
purging of the layers. I also have a "Load Layers" routine that will
reinstall all the "currently recognized base layers" and will also realign
all the colors and linetypes of these base layers. I have even written
code that is buried in the menu functions that will realign a few existing
layers that might be out of alignment due to a older, somewhat abandoned
template that never gets updated, but is sometimes used by others here
in the office (I hate templates for this very reason).
;; Menu Function to load layers.
;; a = layer name  b = color  c = linetype
(defun LOAD_LAYER ( a b c / )
 (if (not (tblsearch "LAYER" a))
  (progn
   (setvar "CMDECHO" 0)
   (command ".layer" "New" a "Color" b a "Ltype" c a "")
   (setvar "CMDECHO" 1)
   (princ (strcat "\n Layer " a " created. "))
  );progn
 );if
 (setq a nil b nil c nil)(princ)
);endLOAD_LAYER
(LOAD_LAYER "Layer1" "7" "CONTINUOUS")
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
”Boost
