Visual LISP, AutoLISP and General Customization
Raster image selection
8 REPLIES 8
Message 1 of 9
946 Views, 8 Replies
Hello--I would like to be able to create a button macro that will take a
selection set and select only raster images. Can anyone tell me how to do
that?
Thanks!
Mike Mattson
8 REPLIES 8
Message 2 of 9
Mike
(ssget "X" '((0 . "IMAGE"))) ;select all images
(ssget '((0 . "IMAGE"))) ;user select with filter for images
Cheers
Juerg Menzi
MENZI ENGINEERING GmbH, Switzerland
http://www.menziengineering.ch
Message 3 of 9
Just one note, which I'm sure both of you know about. If you want to have
the user select the images, the you also need to make sure that imageframe
is turn on. It doesn't look like there is a variable the controls this.
Kevin Nehls
"Jürg Menzi" wrote in message
news:3D5029E1.2095E785@bluewin.ch...
> Mike
> Cheers
> Juerg Menzi
Message 4 of 9
Jurg,
When I use the second of your suggestions--(ssget '((0 . "IMAGE")))--it
allows a selection of objects but doesn't catch the raster images. The
image frames are turned on and visible, the layer is not locked. Any ideas?
Mike Mattson
> Mike
> Cheers
> Juerg Menzi
Message 5 of 9
Mike
(ssget '((0 . "IMAGE"))) works for me in A14, A2k, A2ki and A2k2...
Cheers
Juerg Menzi
Message 6 of 9
Works for me too. Mike, that filter should be filtering out everything
except image objects.
Kevin Nehls
Message 7 of 9
BGERICKO
If I use the selection set to include the raster image (below) how do I use that info to change the raster image to another layer.
(setq ss (ssget "X" '((0 . "IMAGE"))))
Say the Image is located on Layer 50 based on the selection set and I want to put it on Layer 0. How would I write the lisp code to make that change.
Thanks.
Message 8 of 9
Kent1Cooper
in reply to: BGERICKO
@BGERICKO wrote:
.... Say the Image is located on Layer 50 ... and I want to put it on Layer 0. How would I write the lisp code to make that change. ....
One way:
(command "_.chprop" ss "" "_layer" "0" "")
Kent Cooper, AIA
Message 9 of 9
BGERICKO
in reply to: Kent1Cooper
Thanks for the reply, I figured it was a simple code statement.
”Boost
