Not sure if this is the correct NG to post this question but I hope that
there's at least a lisp routine for this somewhere outthere...
I'd like to clip an Raster image so that I would select the polyline to
clip it with. It's an option for Xrefs with Xclip, but with Imageclip
command you only get the option to generate polyline to clip the raster
with not select it if you allready have the polyline drawn.
I tried Xrefing the dwg containing rasters I'd like to clip and then
using Xclip, but that does not clip the images.
Maybe I should also clarify this: in the particular case I'm now working
on I'd like to clip a *single* Raster image with the polyline boundary,
but it would be realy slick if there would be a solution that would clip
a number of stacked and/or overlaid Raster Images to a drawn polyline
boundary. I'm using A2k4 Map.
I hope this has not been asked a zillion times before...
I searched both the 2004General and Costumization NG to no avail.
TIA
Matjaz
