I transferred some shortcut keys to a new cui file.
This is all that I need to transfer to another workstation (R2009).
Heck, I would enterprise the menu if need be.
R2014 will not let me save this as a CUI.
How does one save a cuiX to a CUI?
Search was no help.
scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Hi Scot-65
Well, a .CUIX file is essentially a zipped file ... rename the CUIX extension to ZIP and open it with winZip or winrar.
You will then have access to the separate .CUI files compressed inside (along with all the other menu components' files). It's messy but you can get in there.
Incidentally, you can save a .CUI to a MNU - search on here for: CUI to MNU.vlx and you should find the link to download it in a thread. I just used that last week on an r2013 CUIX > CUI > MNU and it worked just fine!
good luck!
-muddy
Scot-65
Thanks for the heads-up about First Object! .... I think I'll check into that today, myself -- it's getting harder to keep control of legacy menus nowadays messing around with the MNU 🙂
- muddy
Scot-65
