Visual LISP, AutoLISP and General Customization
R2006 and DIMFXL + DIMDXLON dimvars
8 REPLIES 8
Message 1 of 9
Moshe-A
676 Views, 8 Replies
Hi Guys
AutoCAD R2006
Anybody found the way to set DIMFXL + DIMFXLON dimvars programmaticly?
it seen like the only way to set them is from dimstyle dialog box
(even if there is a difference between them and the global dimvars the dialog box doesn't  reflact that) even in the extended data it's not there
thanks in advance
moshe
8 REPLIES 8
Message 2 of 9
pbejse
in reply to: Moshe-A
Doesnt setvar/getvar works on 2006 ?
(setvar 'DIMFXL 144.00)
(setvar "DIMFXLON" 1)
Message 3 of 9
Moshe-A
No
Message 4 of 9
pbejse
@Moshe-A wrote:
No
What about ActiveX"
(vlax-invoke (vla-get-activedocument (vlax-get-acad-object)) 'GetVariable "DIMFXLON" )
(vlax-invoke (vla-get-activedocument (vlax-get-acad-object)) 'SetVariable "DIMFXLON" 0)
(vlax-invoke (vla-get-activedocument (vlax-get-acad-object)) 'GetVariable "DIMFXL" )
(vlax-invoke (vla-get-activedocument (vlax-get-acad-object)) 'SetVariable "DIMFXL" 12)
Message 5 of 9
Moshe-A
in reply to: pbejse
$ (vlax-invoke (vla-get-activedocument (vlax-get-acad-object)) 'GetVariable "DIMFXLON" )
; error: AutoCAD: Error getting system variable
_$ (vlax-invoke (vla-get-activedocument (vlax-get-acad-object)) 'GetVariable "DIMFXL" )
_$
Message 6 of 9
pbejse
I see.
To be on the clear, tell me exactly what you're trying to do?
Message 7 of 9
Moshe-A
i'm writting a small setup program that create Layers, Text Style and Dimension Styles
thank you very much for trying to help.
Moshe
Message 8 of 9
pbejse
Moshe
I tried it on 2007 , its seems to work there, cant find any version lower than that here though. I guess i cant be of any more help Moshe-A.
BTW: what about thru command prompt:?
(command "_setvar" "DIMFXLON" 1)
(command "_setvar" "DIMFXL" 12)
Message 9 of 9
Moshe-A
Ok Thanks
”Boost
