Visual LISP, AutoLISP and General Customization
"text" command not inserting in correct location
4 REPLIES 4
mlittlewood
173 Views, 4 Replies
Hi all,
I have a rough and ready LISP i've been working on that creates a grid for topographical surveys, it prompts the user to select the SW and NE corners of the grid they want, then draws a rectangle, fills the rectangle with a grid of crosses (as blocks) then adds text on each side at regular intervals showing the Easting and Northing values
It used to work just fine, but for some reason now it doesn't insert the Easting / Northing text in the correct place, i haven't changed the main body of the program and it functions fine up until it trys to insert the text.
any ideas? please see attached lisp - i have changed the line that inserts the block "S061" so that it inserts a circle instead, so that it should run and repeat what it's doing on any computer...
4 REPLIES 4
in reply to: mlittlewood
Did you check your osnap mode ?
mlittlewood
i did think it might have had something to do with osnap, as they were all lining up at the endpoints and midpoints of the rectangle, however i always test any variation of the program on a freshly opened drawing from my survey template, as i hadn't changed this i assumed it wasn't osnap
however, if i switch osnap off it now works fine, looks like i was wrong - i will add osnap to the backup variables and hopefully it should work
thanks!
mlittlewood
to confirm; it works perfectly now
thanks again
Glad it works,
You have encountered a classical trap...
Have a good day !
”Boost
