Hi all,
I have a rough and ready LISP i've been working on that creates a grid for topographical surveys, it prompts the user to select the SW and NE corners of the grid they want, then draws a rectangle, fills the rectangle with a grid of crosses (as blocks) then adds text on each side at regular intervals showing the Easting and Northing values
It used to work just fine, but for some reason now it doesn't insert the Easting / Northing text in the correct place, i haven't changed the main body of the program and it functions fine up until it trys to insert the text.
any ideas? please see attached lisp - i have changed the line that inserts the block "S061" so that it inserts a circle instead, so that it should run and repeat what it's doing on any computer...
