"smoothing" out a spline
3 REPLIES 3
8687 Views, 3 Replies
Is there a command that smooths out a spline? I design furniture legs and a command to "smooth" or "soften" my nervous little clicking finer would sure make me feel all warm and fuzzy inside.
Michael
3 REPLIES 3
From the properties panel, raising the "Fit tolerance" will smooth out a spline. Once the spline is sufficiently smooth a
Splinedit - Fit data - Purge
may be appropriate if the spline was destine for export. Message was edited by: SEANT
That will work.
Thanks!
ganthony97E6X
"Fit Tolerance" does not appear to be an option if the spline is a multileader.  Any suggestions?
”Boost
