Put a time stamp check at the end of his code. Use the function, wait a bit,
then switch back to the original doc. Notice the long delay. That original
doc was *not* quiescent.
R. Robert Bell, MCSE
www.AcadX.com
"Jon Fleming" wrote in message
news:VA.00001276.027025dc@fleming-group.com...
| Hum? You totally lost me there. In what sense does Frank's code continue
to
| run after executing?
| jrf
| Member of the Autodesk Discussion Forum Moderator Program
| Please do not email questions unless you wish to hire my services
| In article , R.
Robert
| Bell wrote:
| > It was recently pointed out to me that Frank's code is still running in
the
| > original document in MDI mode. Which may, or may not, be desired. An
| > alternative that does _not_ leave the code running is this function:
| > (defun OpenDwg (fqnName)
| > (command "._VBAStmt"
| > (strcat "AcadApplication.Documents.Open \"" fqnName "\"")))
| > www.AcadX.com
