Visual LISP, AutoLISP and General Customization
Distinguished Contributor
iwafb
Message 1 of 4 (226 Views)
Accepted Solution
"Getradius" similar to getcorner?
226 Views, 3 Replies
06-13-2012 11:13 PM
HI all,
Is there some sort of a getradius function in lisp? I'd like to display a preview of a circle as the user drags the cursor away from the centre point, similar to the way getcorner displays a preview of a rectangle. I have searched this forum and elsewhere, but haven't been able to find anything, so any help will be appreciated.
Thanks in advance.
John
Spoiler
Sorry, silly question (claiming brain fade...).
(initget 1)
(setq pnt1 (getpoint "\nPick first point for detail location..."))
(prompt "\nSpecify size for detail area...")
(command "_.circle" pnt1 pause)
Then delete circle if you want...
iwafb
Message 2 of 4 (224 Views)
Re: "Getradius" similar to getcorner?
06-13-2012 11:36 PM in reply to: iwafb
Spoiler
(initget 1)
Valued Mentor
CADaStroumph
Message 3 of 4 (208 Views)
Re : "Getradius" similar to getcorner?
06-14-2012 01:26 AM in reply to: iwafb
Perhaps this function, return center point and radius.
(defun getradius (pt_cen msg / inc tmp rad p1 p2 lst)
  (setq inc (/ pi 18))
  (princ msg)
  (princ "\nRadius ?")
  (while (= 5 (car (setq tmp (grread t 5 0))))
    (cond
      ((= 5 (car tmp))
        (setq lst nil)
        (redraw)
        (repeat 36
          (setq
            rad (distance pt_cen (cadr tmp))
            p1 (polar pt_cen inc rad)
            inc (+ inc (/ pi 18))
            p2 (polar pt_cen inc rad)
            lst (append lst (list p1 p2))
        (grdraw pt_cen (cadr tmp) 7)
        (grvecs lst)
  (list pt_cen rad)
 Exemple of call in your code:
((lambda ( / pt)
    (initget 9)
    (setq pt (getpoint "\nCenter point: "))
    (getradius pt "\nRadius: ")
diagodose2009
Message 4 of 4 (162 Views)
06-17-2012 10:13 PM in reply to: CADaStroumph
This  source is BEST;;;
If  you  need  convert your program in  C++ADS/C++,please you use my source bellow:
you  can use the source ARX progams.......
[code]
/*c2s:
        inc=(kpi/18);
        mg=str_calloc(msaj,"\nRadius:");
        pt=dfn_var_ispoint(a225);
        initget(9);
        if (pt==nil) pt=ads_getpoint("\nCenter point:");
        princ(mg);
        while( zerop( car(tmp=ads_grread(t,5,0))))
           { if (zerop(car(tmp)),lst=nil;
                 else  { ads_redraw();
                         for (k2=1;k2<36;k2=k2+1)
                            {  rad=ads_distance(pt,cadr(tmp)),
                               p1=ads_polar(pt,inc,rad),
                               inc= (inc+ (kpi/18)),
                               p2=ads_polar(pt,inc,rad),
                               lst=append(lst,lISt(p1,p2));
                         ads_grdraw(pt,cadr(tmp),7);
                         ads_grvecs(lst);
      rr=list(pt,rad);
rr)
[/code]
Post to the Community
New Post
Need installation help?
