Visual LISP, AutoLISP and General Customization
qselect equivalent script needed
3 REPLIES 3
632 Views, 3 Replies
Hi
I need a script to replace the following as I have to use this a lot.
this is what I currently do:-
1, qselect
2, apply to : Entire drawing
3, Object type: polyline
4, properties: Length
5, Operation: =Equals
6, value: fixed size (see below)
7, how to apply: Include in new selection set
8, Append to curent selection set is unticked
9, Delete selection set.
the above gets run 2 time 1 with value of "444.5" next with "63.5" and next with "442.736" ( last one does not allways retune anything but still needs to be run just in case).
can anyone help me out please.
Simon
3 REPLIES 3
phanaem
Try this.
(defun C:TEST ( / *error* ss d ss1 i e)
  (or
    (setq ss (ssget "_I"))
    (setq ss (ssadd))
  (defun *error* (msg)
    (sssetfirst nil nil)
    (and
      msg
      (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*EXIT*"))
      (princ (strcat "\nError: ") msg)
    (sssetfirst nil ss)
  (if
    (setq ss1 (ssget "_X" '((0 . "*POLYLINE"))))
    (while
      (setq d (getdist "\nEnter polyline length: "))
      (repeat
        (setq i (sslength ss1))
        (setq i (1- i)
              e (ssname ss1 i)
        (if
          (equal
            (vlax-curve-getdistatparam e
              (vlax-curve-getendparam e)
            d
            1e-5
          (ssadd e ss)
      (sssetfirst nil ss)
  (princ)
That worked fine thanks for that.
Just the one more question.
The only way I have got any LSP file to run todate is to click on "load Application" in Manage ribben tab is there a way to have this auto load on startup so then I only have to type the command when I need it without haveing to load it each time?
Thanks again for your time.
I have got it working as I need know thanks for your help and time.
Simon
”Boost
