Visual LISP, AutoLISP and General Customization
.qsave in lisp error
6 REPLIES 6
1582 Views, 6 Replies
I've created a custom redefined qsave lisp to run load with acaddoc in ACA09. I've noticed the scrip will work, however on the .qsave command (default undefined) will not open a dialog box... instead it only provides a command line prompt for filename. When .qsave is manually entered immediately after , it will open with dialog box as expected. This happens in all drawings. Filedia is set to 1. Would appreciate any ideas. Lisp below. Thanks!
(command "undefine" "qsave")
(defun c:qsave ()
(command "zoom" "e")
(command ".qsave")
(princ)
6 REPLIES 6
ktuning
Try this?
(defun c:qsave ()
(if (= 1 (getvar "dwgtitled"))
(command ".save" "") ;If already saved, just save it
(command ".save" "~") ;If new drawing, open dialog to save
(princ)
Great! Thanks!!!
Kent1Cooper
It should also work to simply add
(initdia)
just before the
(command ".qsave")
line.
Kent Cooper
Kent Cooper, AIA
Kent1Cooper
I don't think you want the Save command here! It creates a *separate drawing file* [like SaveAs, except that it leaves you in the drawing you're in, instead of taking you into the new one]. It does *not* update the current drawing file. But it still counts as a form of saving, so if you then get out of the drawing you're in, that drawing file will not be updated to the current state of things, because it won't ask whether you want to save your changes!
Be careful about the difference between Qsave and Save and SaveAs. The File pull-down menu's so-called but mis-named "Save" item, and the diskette icon in the standard Toolbar, and Ctrl-S, all perform a Qsave, *not* a Save command, and that's what you should use here. [In a drawing that hasn't been saved/named yet, they all do the same thing by reverting to SaveAs, but not otherwise.]
Kent Cooper
ktuning wrote...
Kent Cooper, AIA
arul_kov
How can i set the new file name in the qsave window
My new file name is "newnumber" as per the below lisp
(defun c:qsave ()
(setq num (car (entsel"\nSelect Existing File number:\n"  )))
(setq texl1 (vlax-ename->vla-object num))
(setq val1(vla-get-TextString texl1 ))
  (setq oldnumber1 (substr val1 3 6) )
  (setq newnumber (strcat "57" oldnumber1) )
  (Princ newnumber)
(command ".save" "~" ) ;If new drawing, open dialog to save
(princ)
Kent1Cooper
in reply to: arul_kov
Look at the (getfiled) function, with its 'default' argument.
Kent Cooper, AIA
”Boost
