Prac_Slip_Kerm
Message 1 of 10 (931 Views)
Put Default Text on Command Line for getstring
931 Views, 9 Replies
06-06-2012 10:31 PM
Hi All,
  I am trying to get a default value (from global variable) put as the default for getstring command. Problem is I want it as if I had typed it into the getstring command so I can modify it if required. It is for entering filenames which only change slightly ie 1129E09LS1 ...LS2 ...XS1 etc.
Any ideas???
Current Code:
(setq BlkName (getstring "\nEnter Civil Cad File to Import: "))
For defaults that I don't want to change I usually use this format:
(or BlkName (setq BlkName (getstring "\nEnter Civil Cad File to Import: ")))
 Thanks In Advance
Cheers
Steve :-)
Play around with this one
(defun c:Test ()
 (setq BlkName (lisped (if (or (null BlkName)
                                      (numberp BlkName))
                                     "" (strcase BlkName))))
(defun c:Test ()
                                      (numberp BlkName))
Hi pBe .
What's this lisped ?? You must have forgotten to add that sub-function  :smileywink:
Distinguished Mentor
_Tharwat
Message 2 of 10 (928 Views)
Re: Put Default Text on Command Line for getstring
06-06-2012 11:13 PM in reply to: Prac_Slip_Kerm
Maybe ..... change the [My File Name] to your needed one .
(if (eq (setq BlkName (getstring  "\nEnter Civil Cad File to Import [My File Name] : ")) "")
  (setq BlkName "My File Name"))
____________________________________________________
Get learn and learn and practice , to become experienced guy .
pbejse
Message 3 of 10 (918 Views)
06-07-2012 01:09 AM in reply to: _Tharwat
(defun c:Test ()
                                      (numberp BlkName))
_Tharwat
Message 4 of 10 (916 Views)
06-07-2012 01:23 AM in reply to: pbejse
(defun c:Test ()
                                      (numberp BlkName))
Hi pBe .
pbejse
Message 5 of 10 (914 Views)
06-07-2012 01:37 AM in reply to: _Tharwat
_Tharwat wrote:
Hi pBe .
Did you try it?
_Tharwat
Message 6 of 10 (910 Views)
06-07-2012 01:42 AM in reply to: pbejse
pbejse wrote:
_Tharwat wrote:
Hi pBe .
Did you try it?
That's awesome . :smileyvery-happy:
Kent1Cooper
Message 7 of 10 (894 Views)
06-07-2012 11:53 AM in reply to: pbejse
                                      (numberp BlkName))
That is awesome, as _Tharwat said.  It is beyond my comprehension why a function like (lisped) would not be included in the AutoLISP Reference [it can't be that it's newer than my old version, because the function is present].  How is anyone supposed to know about it?
Kent Cooper
Prac_Slip_Kerm
Message 8 of 10 (875 Views)
06-07-2012 06:02 PM in reply to: pbejse
Thanks heaps pbejse!!!!
I ended up copying lisped out of acad.dcl and modifying it to suit my needs and using your code.
;Call DCL to display dialog with previous BlkName if it Exists
  (setq BlkName (CCIdcl
		  (if (or (null BlkName) (numberp BlkName));or
		  );if
		 );CCIdcl
  );setq
  ;Check if BlkName /= ""
  (cond
    ((= "" BlkName)
      (princ "\n No Filename Entered - Function Cancelled")
    );Cond BlkName = ""
    ( T
      (progn
        ... Code to run here ...
      );progn
    );cond BlkName Exists
  );cond
 lisped changed to CCIdcl, modified labels & removed mtext editor button
(defun CCIdcl (contents / fname dcl state)
  ;;;(if (not (setq fname (getvar "program")))
  (setq fname "BK-Std")
  (strcat fname ".dcl")
  (setq dcl (load_dialog fname))
  (if (not (new_dialog "CCI" dcl)) (exit))
  (set_tile "contents" contents)
  (mode_tile "contents" 2)
  (action_tile "contents" "(setq contents $value)")
  (action_tile "accept" "(done_dialog 1)")
;;;  (action_tile "mtexted" "(done_dialog 2)" )
  (setq state (start_dialog))
  (unload_dialog dcl)
  (cond
    ((= state 1) contents)
    ((= state 2) -1)
    (t 0)
  );cond
);defun
 Thanks again for your help!
Cheers
Steve :-)
pbejse
Message 9 of 10 (864 Views)
06-07-2012 09:54 PM in reply to: Prac_Slip_Kerm
You are welocme, glad i could help
Keep on coding,
Cheers
pbejse
Message 10 of 10 (847 Views)
06-08-2012 04:35 AM in reply to: Kent1Cooper
Cool huh? :smileyhappy:
One soruce is thru atoms-list function, when evaluating  an item you will get #<USUBR @161e3e24 LISPED> , and its unrecognizable  then you'll start to wonder what that is...the local search button on this forum or Mr. google will find it for you.
Most of the time i just jumped from one forum to another. :smileyvery-happy:
Another source is  JTB World Undocumented section  or Manusoft
HTH
