Hello everyone
I have a this lisp that tags conduits with a multileader. Is there a way to make it work the same way with dynamic blocks which can include layer, blockname, all attributes and parameter values in a multileader? output text inside multileader would be like:
Layer: block1
Visibility:
Length: 5'-0"
Attribute: note
Please help. Thanks in advance
(defun c:cndtag (/ CNDEnt CNDObj PickPoint TagPoint CNDSize CNDSystem CNDTag) (vl-load-com) (if (and (setq CNDEnt (entsel "\nSelect the conduit to tag... ")) (setq CNDObj (vlax-ename->vla-object (car CNDEnt))) (setq PickPoint (osnap (cadr CNDEnt) "nea")) (setq TagPoint (getpoint PickPoint "\nPosition of conduit tag... ")) (vlax-property-available-p CNDObj "SizeName") (setq CNDSize (substr (vlax-get-property CNDObj "SizeName") 1 4)) (vlax-property-available-p CNDObj "Description") (setq CNDSystem (vlax-get-property CNDObj "Description")) ) (progn (cond ((= (substr CNDSize 2 3) ".00") (setq CNDSize (substr CNDSize 1 1))) ((= (substr CNDSize 2 3) ".25") (setq CNDSize (strcat (substr CNDSize 1 1) " 1/4")) ) ((= (substr CNDSize 2 3) ".50") (setq CNDSize (strcat (substr CNDSize 1 1) " 1/2")) ) ((= (substr CNDSize 2 3) ".75") (setq CNDSize (strcat (substr CNDSize 1 1) " 3/4")) ) ) (if (= (substr CNDSize 1 2) "0 ") (setq CNDSize (vl-string-left-trim "0 " CNDSize)) ) (setq CNDTag (strcat CNDSize "\" C, " CNDSystem)) (command "_MLEADER" PickPoint TagPoint CNDTag) ) ) (princ) )
Solved by hmsilva. Go to Solution.
Layer: block1
Visibility:
Length: 5'-0"
Attribute: note
Hi JCprog,
as a 'demo':
(vl-load-com) (defun c:demo (/ a atts b lst obj osm pt pt1 ss str) (if (and (setq osm (getvar 'OSMODE)) (setvar 'OSMODE 512) (setq pt (getpoint "\nSelect a Dynamic Block to tag: ")) (setvar 'OSMODE osm) (setq ss (ssget pt '((0 . "INSERT")))) (setq obj (vlax-ename->vla-object (ssname ss 0))) (vlax-property-available-p obj 'IsDynamicBlock) (eq (vla-get-IsDynamicBlock obj) :vlax-true) (setq pt1 (getpoint pt "\nPosition of Dynamic Block tag:")) ) (progn (setq lst (cons (list "Layer: " (vla-get-Layer obj)) lst) lst (cons (list "Name: " (vla-get-EffectiveName obj)) lst) ) (foreach p (vlax-safearray->list (vlax-variant-value (vla-getdynamicblockproperties obj)) ) (if (and (/= (setq a (vlax-get p 'PropertyName)) "Origin") (setq b (vlax-get p 'Value)) ) (setq lst (cons (list (strcat a ": ") (vl-princ-to-string b)) lst)) ) ) (if (and (vlax-property-available-p obj 'Hasattributes) (eq :vlax-true (vla-get-hasattributes obj)) ) (progn (setq atts (vlax-invoke obj 'Getattributes)) (foreach att atts (setq lst (cons (list (strcat (vla-get-tagstring att) ": ") (vla-get-textstring att) ) lst ) ) ) ) ) (setq str (vl-string-right-trim "\\P" (apply 'strcat (mapcar (function (lambda (x) (strcat (car x) (cadr x) "\\P"))) (reverse lst) ) ) ) ) (command "_.mleader" "_NONE" pt "_NONE" pt1 str) ) (prompt "\nNot a Dynamic Block!") ) (princ) )
Hope that helps
Henrique
Hello Henrique,
This works awesome! but for some reason it seems like its cutting short when it comes to the attributes.
Its printing fine for the first 7 lines (I'm getting 2 Properties and 5 parameters and after that it cuts off) whereas the block has 5 more attributes
Layer: layer1
Visibility: wide
LEADER DISTANCE: 7.08473
LEADER ANGLE: 0.0
Flip state1: 0
Flip state2: 0
de
*the de at the last line suppose to description
Hi JCprog,
AutoLISP as a restriction on a string length, 132 characters...
I dont have AutoCAD in this laptop, but should work as expected, change
to
(command "_.mleader" "_NONE" pt "_NONE" pt1 "") (setq obj (vlax-ename->vla-object (entlast))) (vla-put-textstring obj str)
HTH
Henrique
