alan1959
Message 1 of 15 (273 Views)
Purge on Exit
273 Views, 14 Replies
01-10-2012 01:32 PM
I am trying to "purge on exit" when I close a drawing. I have changed the SAVE commands within the CUI to accomplish a purge on save as well as changed the CLOSE commands in the CUI.
What I want to do is modify the red X close option for the actual windowor program close X in the top right corner of the screen. Any help on how I can do this would be appreciated. Thanks.
Lee_Mac
Message 2 of 15 (269 Views)
Re: Purge on Exit
01-10-2012 01:55 PM in reply to: alan1959
Use an Editor Reactor, triggered upon the BeginClose Event to evaluate a callback function which calls the PurgeAll method of the Document Object. The only downside is that the PurgeAll method will not purge Multileader Styles, but you will not be able to use a call to the command version from a reactor callback function.
Something along the lines of:
(if (null *editor-reactor*)
    (setq *editor-reactor* (vlr-editor-reactor nil '((:vlr-beginclose . purgedwg))))
(defun purgedwg ( reactor params )
    (if (null *acdoc*)
        (setq *acdoc* (vla-get-activedocument (vlax-get-acad-object)))
    (if (= 1 (getvar 'DWGTITLED))
        (progn
            (repeat 3 (vla-purgeall *acdoc*))
            (vla-save *acdoc*)
    (princ)
(vl-load-com)
Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
Expert Elite
With Mathematics there is the possibility of perfect rigour, so why settle for less?
alan1959
Message 3 of 15 (267 Views)
Re: Purge on Exit
01-10-2012 01:58 PM in reply to: alan1959
how do I load this or where do I insert this to make it run automatically?
Lee_Mac
Message 4 of 15 (260 Views)
Re: Purge on Exit
01-10-2012 02:07 PM in reply to: alan1959
As you can see there is no command syntax for the program since the reactor will fire automatically, you just need to ensure the code is loaded into the drawing.
The code can be loaded in the same way as you would with any other LISP program, using either the ACADDOC.lsp (recommended) or Startup Suite in the AppLoad dialog.
My tutorial here may help you in this respect.
Lee
Expert Elite
Patchy
Message 5 of 15 (255 Views)
Re: Purge on Exit
01-10-2012 02:17 PM in reply to: Lee_Mac
Hi Lee
Why it didn't work until I moved the line (vl-load-com) at the bottom to the top of the code and it worked perfectly?
Patchy
Lee_Mac
Message 6 of 15 (249 Views)
Re: Purge on Exit
01-10-2012 02:34 PM in reply to: Patchy
Patchy wrote:
Hi Lee
Oops! Sorry, yes (vl-load-com) should be at the top.
The reactor is initialised at the top, this requires Visual LISP.
Expert Elite
alan1959
Message 7 of 15 (245 Views)
Re: Purge on Exit
01-10-2012 03:10 PM in reply to: alan1959
Okay this worked like a charm. Now to throw a wrench in the works.... it there a way to have the purge not function if when exiting you want to click on the NO option for saving changes when exiting? As it works now it purges no matter what and saves the drawing even if you click NO to saving changes.
Lee_Mac
Message 8 of 15 (218 Views)
Re: Purge on Exit
01-11-2012 04:20 AM in reply to: alan1959
Try this:
(vl-load-com)
    (if (null *acdoc*)
    (if
        (and
            (= 0 (getvar 'DBMOD))
        (progn
            (vla-save *acdoc*)
    (princ)
(princ)
Expert Elite
Valued Mentor
alanjt_
Message 9 of 15 (210 Views)
Re: Purge on Exit
01-11-2012 07:30 AM in reply to: Lee_Mac
What if certain changes are made within the startup (layers, styles, etc. inserted)? The dbmod variable will be something other than 0.
Wouldn't it just be safer to add a purge call to the startup and/or have a custom close+purge+save command?
Also, while it is minor, know that vla-purgeall will not include MLeader styles.
Lee_Mac
Message 10 of 15 (199 Views)
Re: Purge on Exit
01-11-2012 09:22 AM in reply to: alanjt_
 Yes, but this would have no effect on the correct evaluation of the callback function, since, if the DBMOD variable is something other than zero when the user closes the drawing, the 'Save Changes' prompt will appear - If the user decides not to save changes, the DBMOD remains non-zero and the drawing is not purged. If the user decides to save changes, the DBMOD is reset to zero and the drawing is purged as expected.
Lee_Mac wrote:
The only downside is that the PurgeAll method will not purge Multileader Styles...
Expert Elite
