Properties > Display locked > (Yes, No)
0 REPLIES 0
Message 1 of 1
150 Views, 0 Replies
Hi --
I'm running Map 3D 2008, XP Pro.
If I select a Layout Viewport in paperspace, then click on the Properties toolbar button, go to the Misc block and choose the Display Locked line, I then have a choice (from a small dropdown list) of Yes or No.
The Yes choice prevents movement of the Model within the viewport (can't zoom or pan).
QUESTION: is there a toolbar command, that can be attached to a custom toolbar button, to Lock (= Yes) or Unlock (= No) the Display?
This would eliminate several mouse clicks each time I need to unlock and re-lock a paperspace viewport.
I've combed the Help files and CUI, and can't find anything. I thought I found it with **Viewports, Lock, Yes** (^C^C_-vports _lock _on _p;;) and **Viewports, Lock, No** (^C^C_-vports _lock _off _p;;).... But those commands don't seem to behave the way I need them to -- and the Help files are not very helpful.......
Thanks, John Cutler
0 REPLIES 0
”Boost
