Visual LISP, AutoLISP and General Customization
Prompt to update through Lisp
14 REPLIES 14
Message 1 of 15
JCprog
724 Views, 14 Replies
Hello Everyone!!!!!
A dozen of computers have a Partial cuix stored locally (C:\My cui) and in the network (N:\Network). These computers gets there cui updated through a batch file (.bat) that just simply copies the files from the network to (C:\My cui). All computers needs to be independent and not tied to the network thats why I set it this way.
Need help on a lisp that will compare (C:\My cui\updatelog.txt) & (N:\Network\updatelog.txt). If the txt files dont match prompt the user with a popup asking if he wants to update (yes\no) if yes then run batch (C;\My cui\run.bat) file otherwise cancel.
Thanks in advanceSmiley Happy
14 REPLIES 14
Message 2 of 15
dgorsman
in reply to: JCprog
- connect to each file
- read the contents of each file into a list of strings
- shortcut test: compare number of lines
- for each line in one list (shouldn't matter which one)
   - if the contents of the matching index of the other list don't match the current line
      - set a flag
      - shortcut the loop
- next list entry
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 3 of 15
BlackBox_
in reply to: JCprog
You might consider the vl-File-Systime function:
(vl-load-com)
(defun _FilesAreUpToDate (local network)
  (equal (vl-file-systime local) (vl-file-systime network))
"How we think determines what we do, and what we do determines what we get."
Message 4 of 15
in reply to: BlackBox_
My company started using Dropbox.  Putting CAD support files in a Dropbox (or other cloud hosting service) folder and mapping it to a drive letter is extremely useful for managing CAD standards while making them available to users who are not connected to your netowrok.  The files all live on each workstation and dropbox handles all the syncing through any internet connection.  You may consider implementing something similar.  Our version does not have permission management but I believe Dropbox released a professional version last Nov. that does allow read/write permission settings.
Message 5 of 15
BlackBox_
I agree that such file-sync services are useful; just be mindful that read-only files (those that are currently open in AutoCAD; CUIx, DLL, etc.) are not able to be overwritten... Thus, an 'update' may not necessarily be performed automagically... And may still require similar mechanism by which to notify user, and prompt to update now, etc.
Cheers
Message 6 of 15
JCprog
Hello BlackBox,
Thanks for the reply! I took a stab at it and returns "Too few arguments". this is just beyond me.
(vl-load-com)
(defun c:FilesAreUpToDate (local network)
  (equal (vl-file-systime "C:/folder1/local.txt")
	(vl-file-systime C:/folder1/network.txt))
 I tend to:
1. compare the files first (the code above)
2. prompt user to update if files not equal
3. when "Yes" then run batch file
Message 7 of 15
BlackBox_
in reply to: JCprog
@JCprog wrote:
Hello BlackBox,
(vl-load-com)
 I tend to:
You've unintentionally broken the code by adding the "c:" prefix to a sub-function that requires two arguments... LISP Commands (those that include the "c:" prefix) should not require parameters in this way. Also, your second, network path is missing quotes.
Instead, consider this example (batch file not required):
(vl-load-com)
(defun c:UPDATE (/ _FilesAreUpToDate local network)
  (if
    (_FilesAreUpToDate
      (setq local "C:/folder1/local.txt")
      (setq network "C:/folder1/network.txt")
     (prompt "\n** No update required ** ")
     (if (vl-file-delete local)
       (progn
	 (vl-file-copy network local)
	 (prompt "\n** Local file updated ** ")
       (prompt "\n** Unable to delete local file ** ")
  (princ)
Message 8 of 15
JCprog
That worked flawlessly!
Comparing the two text files and updating both is achieved.
The updating part needs to be the whole folder. Inside folder contains various files including the text file. I would just like the text file to be the key for comparison but update the entire folder contents.
Message 9 of 15
JCprog
in reply to: JCprog
......Or can I just simply use the two folders to compare instead of the text files?
Edit:
I stand corrected, It doesnt recognize the folders modified date
Message 10 of 15
BlackBox_
in reply to: JCprog
That is kind of you to say, JCprog.
Perhaps I overlooked your stating that you needed to update the entire folder earlier... For that you can do (at least) one of two things:
1) Iterate the contents of the network folder's files, and compare them each, updating if either out of date, or if the local version does not exist.
2) Instead rely on your batch file.
I'd personally opt for the former (others may disagree, and may also be smarter than I), for the simple reason of only updating what needs to be updated.
Here's a quick example of that (untested):
(vl-load-com)
(defun c:UPDATE (/ local network _FilesAreUpToDate file)
  ;; set local and network folders
  (setq local "C:/folder1/")
  (setq network "N:/folder1/")
  ;; file check sub-function
  ;; foreach file found in the network folder
  (foreach netFile (vl-directory-files network "*.*" 1)
    ;; if the file can be found locally
    (if (findfile (setq file (strcat local netFile)))
      ;; then, if the files are up-to-date
      (if (_FilesAreUpToDate file (strcat network netFile))
	;; then, no update required
	;; else, if the local file can be deleted
	  ;; then,
	  (progn
	    ;; copy the network file to local
	    ;; notify user of successful file update
	    (prompt (strcat "\n** File \"" netFile "\" updated ** "))
	  ;; else, notify user file cannot be deleted
	  (prompt (strcat "\n** Unable to delete file \"" netFile "\" ** "))
      ;; else, copy the network file to local
      (vl-file-copy (strcat network netFile) file)
  (princ)
... Just be mindful of local, read-only files not being updated... That may require an alternative means by which to update, if said files become read-only prior to AcadDoc.lsp being loaded in the startup sequence.
Cheers
Message 11 of 15
JCprog
been playing with the code a lil but bumped into a minor hiccup:
(vl-load-com)
  (if
    (_FilesAreUpToDate
      (setq network "N:/folder1/network.txt")
     (if (startapp "C:/copyNET2LOCALtest.bat")
       (progn
  (princ)
 The hiccup:
The code above runs the batch file but seems to skip comparing the two text files and just run the batch file whether text files are equal or not.
Message 12 of 15
BlackBox_
in reply to: JCprog
(vl-load-com)
  (if
    (_FilesAreUpToDate
       (progn
  (princ)
 The hiccup:
What are the vl-File-SysTime values for each file?
Also, no need for the PROGN statement when there's only a single expression to evaluate (i.e., your PROMPT call).
Message 13 of 15
JCprog
When the local is up to date (meaning both folders are identical) and run the routine......it still runs the batch and skips this part:
 Part of your original code is:
       (progn
 somewhere along the code needs:
 In place of:
vl-file-delete
and
vl-file-copy
Message 14 of 15
JCprog
I got it!!!!!!!!!! I thinkSmiley Happy
(vl-load-com)
  (if
    (_FilesAreUpToDate
      (setq local "C:/folder1/update.txt")
      (setq network "N:/folder1/update.txt")
       (progn
  (princ)
 Your original code worked from the very start. I just changed the vl-file-copy line to execute the batch file instead. Not sure if its the right way to go but it performed the way I need it to beSmiley Happy
Thanks a million BlackBox!!!!!!!!!!!!
Message 15 of 15
BlackBox_
in reply to: JCprog
You're welcome, JCprog; I'm happy to help. :beer:
Cheers
”Boost
