Visual LISP, AutoLISP and General Customization
Progress Meter (repost)
6 REPLIES 6
hulioman
338 Views, 6 Replies
Is there a way to show progress in a routine? I have a routine that currently princs the precentage done from each pass of a repeat. Is there something out there that displays a progress meter at the bottom of the command prompt or something similar? for example (meter 50) would display 50% done. I have seen this with 3rd party softwares...
6 REPLIES 6
in reply to: hulioman
ALLCAPS.LSP from
http://www.turvill.com/t2/free_stuff
will do what you want.
Please don't cross-post.
___
"David K." wrote in message
news:EAA7AC464389A153059925DB185E6468@in.WebX.maYIadrTaRb...
> I'd like to either be able to
> change more than one line of text at a time using a selection set
Try this.  This is an DCL
example:
_________________________________
Timothy Spangler
"You cannot escape the responsibility of tomorrow by evading it
today"
Abraham Lincoln
AutoCAD 2002
WinXP
Compaq Evo W6000
Intel Xeon / 1G RAM
Is
Doslib offers that.... Can't tell you much more
than that. But worth checking out.
Is
something similar?
done.
softwares...
Doslib...
Is
BillZ
(dos_progbar "title" amount)
Allows you to use the built in AutoCAD progress bar.
Dos_getprogress gives you a modeless box on the screen.
Bill
DParcon
Try this crude implementation....
(setq num 1000
cnt 0.0
incr (/ 1.0 num)
(repeat num
(setq pct (fix (* 100 (setq cnt (+ cnt incr)))))
(princ (strcat "\r" "...Processing..." (itoa pct) "% Done..."))
(rest of your code here.......)
);repeat........Don
”Boost
