Visual LISP, AutoLISP and General Customization
Program exit - "Command:" listed twice
24 REPLIES 24
Message 1 of 25
HS20EXR
2651 Views, 24 Replies
Does anybody know why some programs list "Command:" twice while others exit cleanly and list "Command:" at the end of the program only once (as they should, I guess)?
Here's a simple example where command is listed twice after the program is run:
(defun c:test ()
  (if (setq Ent (car (entsel)))
    (progn
      (setq ELst (entget Ent '("ACAD")))
      (setq XData (assoc -3 ELst))
      (if XData
	(progn
	  (foreach XDe (cadr XData)
	    (print XDe)
	(prompt "\nThis is a test.")
  ) ;end if
  (princ)
) ;end defun
 When I run the program I get:
Command: test
Select object:
This is a test.
Command:
Command:
How can I get rid of the extra "Command:" line?
Thanks.
24 REPLIES 24
Message 2 of 25
Kent1Cooper
in reply to: HS20EXR
(defun c:test ()
    (progn
      (if XData
	(progn
	    (print XDe)
  ) ;end if
  (princ)
) ;end defun
Command: test
Select object:
This is a test.
Command:
Command:
Does it put up two of them under all possible conditions, i.e. when you select an object that has extended data and when you select one that doesn't and when you miss in picking something?  Or does it put up only one under one or another of those conditions?  I'm just wondering whether the extra might be caused by a nil return from one or another of the (if) test functions.
By the way, I would suggest a slight re-arrangement at the beginning.  This line:
will, if the User misses when picking something, not merely return nil but will generate an error, because (entsel) will return nil, so (car) won't have an entity-selection list to get the first item from.  That error can be avoided by doing something like this:
  (if (setq esel (entsel)); nil return here just goes to 'else' expression, without error
    (progn ; then [User successfully picked on something]
      (setq Ent (car esel)); moved out of (if) test expression
Kent Cooper, AIA
Message 3 of 25
HS20EXR
in reply to: Kent1Cooper
Thanks for your reply.
I re-arranged the code as you suggested. It still puts up two "Command:" lines at the end of the program under ALL conditions (XData, no XData, missing picking object). Do you think the extra "Command:" is generated by an error I cannot catch?
(defun c:test (/ esel EList Xdata XDe)
  (if (setq esel (entsel "\nSelect obj to list XData:"))
    (progn
      (setq ELst (entget (car esel) '("ACAD")))
      (if XData
	(progn
	  (terpri)
	    (print XDe)
	(prompt "\nNo XData.")
  ) ;end if
  (princ)
Message 4 of 25
hmsilva
Thanks.
HS20EXR,
some programs list "Command:" twice, because the first command listed is the last value return.
A simple test, with
(defun c:test1 (/ p)
  (if (setq p (getpoint "\nPick a point: "))
    (vl-cmdf "point" p)
  );; if
);; test
We'll have this command line echo:
Command: test1
Pick a point: point
Current point modes:  PDMODE=0  PDSIZE=0.0000
Specify a point:
Command: T
Command:
As your code ends with the princ function, the command line displays nothing, because there is nothing to return, nor nil or T, but there is an empty echo...
To suppress that echo, you'll probably have to deal with the CMDECHO SysVar and some Error Handling...
With your code, if you have Express Tools, the easiest way is
(defun c:test ( / esel ELst Xdata XDe)
(acet-error-init
 (list (list "cmdecho" 0
       );; list
       T
 );; list
);; acet-error-init
    (progn
      (if XData
	(progn
	  (terpri)
	    (print XDe)
      );; if
    );; progn
    (prompt "\nNo Obj.")
  );end if
(acet-error-restore)
);; test
HTH
Henrique
Message 5 of 25
HS20EXR
in reply to: hmsilva
Thank you Henrique. This makes it more clear now.
Message 6 of 25
hmsilva
You're welcome, HS20EXR
Henrique
Message 7 of 25
HS20EXR
I realized I still get the second "Command" line in case of error - hitting ESC when asked to pick an obj. Whould you know what error function to use to get rid of it?
I tried
(defun *error* (msg)
  (princ msg)
  (setvar "cndecho" 1)
  (princ)
 but doesn't seem to be working.
Message 8 of 25
hmsilva
I tried
  (princ msg)
  (princ)
I don't know.
I will do some tests...
Henrique
Message 9 of 25
Kent1Cooper
I tried
  (princ msg)
  (princ)
That n in "cndecho" might be the culprit, since it would generate an error about a non-existent System Variable -- correct it to an m and see whether it still does it.
Kent Cooper, AIA
Message 10 of 25
hmsilva
HS20EXR,
again, using Express Tools
(acet-error-init
       );; list
       0
 );; list
);; acet-error-init
    (progn
      (if XData
	(progn
	  (terpri)
	    (print XDe)
      );; if
    );; progn
  );end if
);; test
Hope that helps
Henrique
Message 11 of 25
HS20EXR
Thank you, Henrique, it looks like it's working.
Message 12 of 25
hmsilva
Henrique
Message 13 of 25
HS20EXR
Henrique, I am getting the following errors in some programs that use (acet-error-init) (acet-error-restore) :
(*pop-error-mode*) underflow.AutoCAD variable setting rejected: OSMODE nil
After that, none of the programs that use (acet-error-init) (acet-error-restore) work. Would you have any suggetions?
Message 14 of 25
john.uhden
I ran into this years ago, probably starting with R15.
Your function does not call any AutoCAD (command)s.  If you include just one (command ...) then your excessive echo will go away.
What I always use is:
(setvar "cmdecho" 0)
(command "_.expert" (getvar "expert"))
;; NOTE - Reset cmdecho somewhere before your function completes.
John F. Uhden
Message 15 of 25
HS20EXR
in reply to: john.uhden
Thanks for the suggestion,
john.uhden. I was trying to apply it and it didn't work, I don't think I understood correctly it.  Here's an example:
(defun c:te ()
  (princ msg)
  (setvar 'osmode osmode)
  (setvar 'cmdecho 1)
  (princ)
) ;defun
;;;  (acet-error-init (list (list "cmdecho" 0) 0))
  (setvar 'cmdecho 0)
  (setq osmode (getvar 'osmode))
  (setq obj1 (entlast))
  (setq p1 (getpoint "Pick a point "))
  (setvar 'osmode 0)
    (command "_copy" obj1 "" p1 "" 3)
  (setvar 'cmdecho 1)
;;;  (acet-error-restore)
What I get after I run it is: Command: te Pick a point 3
1.
If I activate (acet-error-init (list (list "cmdecho" 0) 0)) and (acet-error-restore) it runs cleanly, but for some programs I get the errors I mentioned in the first post and I cannot run any programs that use that code until I close and open the drawing again.
Message 16 of 25
HS20EXR
Actually I tried your suggestion for some different programs and it seems to work. Thank you, I appreciate your help.
Message 17 of 25
john.uhden
I'm running 2002, so things may have changed, but I don't understand
I could understand
(command "_copy" obj1 "" p1 p2)
What purpose are the "" and 3 at the end of the copy command?
I think that's where your problem is.
John F. Uhden
Message 18 of 25
HS20EXR
"" & 3 are supposed to copy the object at 3 units distance. I tested the code and it worked for me, but it's not a very good example. Anyway, I tried your suggested code on a few programs and it worked nicely, I got rid of the extra echo. Thank you, it's a simple and nice solution, I appreciate your help.
Message 19 of 25
john.uhden
I love hearing good news!
John F. Uhden
Message 20 of 25
HS20EXR
I came across a program that keeps giving me the extra "command" after I exit it. I was wondering if you had any idea how to fix it. It emulates LINE command and it resets DYNMODE variable to 0 (it gets set to 2 from other program I run and cannot reset back unless I do it manually).  iset cmdecho to 1 so I can see the prompts on the screen.
(defun c:test (/ *error*)
  (princ msg)
  (princ)
  (setvar 'cmdecho 1)
  (setvar 'dynmode 0)
  (command "_.line")
  (while (/= (getvar "cmdactive") 0)
    (command pause)(terpri)
  (princ)
”Boost
