Profiles with diffirent cuix.
2 REPLIES 2
264 Views, 2 Replies
Hi there,
I have created to new profiles:  Pro1 & Pro2.
I also have 2 new .cuix's, they were made automatically when I
menuloaded my old .mns files.  They are called Cu1 andd Cu2
I want Pro1 to contain Cu1 &
I want Pro2 to contain Cu2
The roblem I am having is when I menuload any cuix file it appears
in each profile, It has been so long since I did this that I can't figure
out why, can anybody help?
Thanks you in advance.
Martin.
2 REPLIES 2
Alfred.NESWADBA
the command _MENULOAD does just add the CUIX as a partial menu to the existing main-CUIX.
To change the main-CUIX you have to use the command _MENU instead.
BUT: be careful, if your CUI1.CUIX or CUI2.CUIX does not contain workspaces you would have to create them from scratch.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Hi there,
thanks for your help, this has helped me get a step further to sorting my problem.
Ta,  :D..
”Boost
