Processing multiple items
4 REPLIES 4
bdsmls
232 Views, 4 Replies
I've tried to figure out how to make this work and i'm stumped.
I want to select multiple items and run a set of commands for each item individually.
the routine draws a detail of the selected items and works great if the items i select are identical in every way,
otherwise it details only the first item in the group.
any help would be greatly appreciated
Larry
this is my condensed routine:
(DEFUN C:MYROUTINE()
(PROMPT "\n\n\nSelect items to detail:")
(SETQ OBJECT(SSGET))
(SETQ PQTY(SSLENGTH OBJECT))
(SETQ NP1(SSNAME OBJECT 0))
(SETQ N1(CDR(ASSOC 0(ENTGET NP1))))
(IF(= N1 "ENGCENTITY")(PROGN...
   (run a series of definitions)
(DEFUN DRAWEC()
(IF(= PTYPE "A")(PROGN...
   (define a series of points)
(COMMAND "PLINE" P1 "W" "0" "" P2 P3 P4 "C" "")
(REPEAT PQTY (DRAWEC))
(PRINC))
4 REPLIES 4
Lee_Mac
in reply to: bdsmls
bdsmls
in reply to: Lee_Mac
i'll check it out
thanks
bdsmls
i don't know what i'm missing, but it's still draws all details with the parameters of the first item in the selection set
hmsilva
in reply to: bdsmls
If I understood correctly, perhaps something like this
(DEFUN C:MYROUTINE ()
  (DEFUN DRAWEC	()
    (IF	(= PTYPE "A")
      (PROGN...
      );; progn
    );; if
  );; DRAWEC
(if (SETQ OBJECT (SSGET))
  (progn
    (SETQ PQTY (SSLENGTH OBJECT))
    (while (SETQ NP1 (SSNAME OBJECT 0))
      (SETQ N1 (CDR (ASSOC 0 (ENTGET NP1))))
      (IF (= N1 "ENGCENTITY")
	(PROGN...
	  (DRAWEC)
	);; progn
      );; if
      (ssdel NP1 OBJECT)
    );; while
  );; progn
);; if
(PRINC)
);; MYROUTINE
hope that helps
Henrique
”Boost
