Problems with getpoint and UCS away from origim
2 REPLIES 2
gustavobernardi
429 Views, 2 Replies
Hi Guys, I have a problem with some lisps. I capture the point with getpoint and when designing and using the acquired point, the object is not in the right position. the problem only occurs when the UCS is away from origin. follows one of lisps: [code] (defun c:AREAFIELDMETER (/ Get-ObjectIDx64 space ss pt) (defun Get-ObjectIDx64 (obj / util) (setq util (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object)))) (if (> (vl-string-search "x64" (getvar "platform")) 0) (vlax-invoke-method util "GetObjectIdString" obj :vlax-False) (itoa (vla-get-Objectid obj)) ) ) (setq space (vla-get-modelspace (vla-get-ActiveDocument (vlax-get-acad-object)) ) ) (if (and (setq ss (car (entsel "\n Select Object for Area : "))) (setq pt (getpoint "\n Specify Text Location :")) ) (vla-addMText space (vlax-3d-point pt) 1. (strcat "%<\\AcObjProp Object(%<\\_ObjId " (Get-ObjectIDx64 (vlax-ename->vla-object ss)) ">%).Area \\f \"%lu2%pr2%ps[, m²]%ct8[1]\">%" ) ) (princ) ) (princ) (c:AREAFIELDMETER) [\ code]
2 REPLIES 2
BlackBox_
in reply to: gustavobernardi
Consider the TRANS function after you've specified the desired point(s).
Cheers
"How we think determines what we do, and what we do determines what we get."
gustavobernardi
in reply to: BlackBox_
Solved: (setq pt (getpoint "\n Specify Text Location :")) (setq PT (trans pt 1 0)) Thanks
”Boost
