Visual LISP, AutoLISP and General Customization
Problem insert block which attributes cad 2014
3 REPLIES 3
andresep82
1901 Views, 3 Replies
Hello again¡¡¡
I am testing de new version of autocad 2014 and i have a problem which me lips.
when i use
(command "_insert" "block1" pt1 "" "" ""  obj1 )
The block is inserted but without value. In the old version work.Some variable that has to change?
Sorry for my english.
3 REPLIES 3
_Tharwat
in reply to: andresep82
Consider the following as an example only . (assume that your Attributed Block has only one attribute )
(setq att (getvar 'attdia))
(setvar 'attdia 0)
(command "_.-insert" "block1" "_none" pt1 "" "" "Tharwat")
(setvar 'attdia att)
pbejse
@andresep82 wrote:
Hello again¡¡¡
when i use
or more likely ATTREQ 0 to 1
andresep82
thanks¡¡¡¡¡
ATTREQ 1,   It has been the solution.
”Boost
