Hello again¡¡¡
I am testing de new version of autocad 2014 and i have a problem which me lips.
when i use
(command "_insert" "block1" pt1 "" "" "" obj1 )
The block is inserted but without value. In the old version work.Some variable that has to change?
Sorry for my english.
Solved by pbejse. Go to Solution.
Consider the following as an example only . (assume that your Attributed Block has only one attribute )
(setq att (getvar 'attdia)) (setvar 'attdia 0) (command "_.-insert" "block1" "_none" pt1 "" "" "Tharwat") (setvar 'attdia att)
@andresep82 wrote:Hello again¡¡¡
when i use
(command "_insert" "block1" pt1 "" "" "" obj1 )The block is inserted but without value. In the old version work.Some variable that has to change?
or more likely ATTREQ 0 to 1
