Distinguished Mentor
Moshe-A
Message 1 of 6 (1,073 Views)
problem in callback function
1073 Views, 5 Replies
09-15-2012 03:17 PM
Hi Guys,
i have encounter a problem in callback function...i am using (client_data_file) to attach string (in a list)
to be transfer to callback function. in the callback i set a local variable to get this string and autocad set it
to nil but if i declare the variable as global it works (not sure if it is a steady problem)
does any one seen this or am i  missing something?
here is an example of my code:
(setq some_string "abcde")
(client_data_tile "accept" "(some_string)")
(action_tile "accept" "(ctrl_accept $data)")
(defun ctrl_accept (data / str)
 (setq str (eval (car (read data)))) ; this returns nil
 (done_dialog 1)
; but this one works
(defun ctrl_accept (data)
 (setq str (eval (car (read data)))) ; this returns "abcde"
 (done_dialog 1)
thanks in advance
Moshe
Scot,
i have changed the local variable name and it seems that autocad is pleased with that
(wonder why in callback a local variable 'filename' is not accepted but 'fname' does -
undocumented bug?) hope it will stay
Scot, could you take a look at my other theard TDINDWG v TDUSRTIMER?
thanks
Moshe
scot-65
Message 2 of 6 (1,036 Views)
Re: problem in callback function
09-17-2012 03:24 PM in reply to: Moshe-A
For your first defun you declare a local variable STR which does not leave the
confides of the opening and closing parenthesis of the defun. In other words,
it is a local variable that stays local. If you want it to leave this area, you show
one of the many tricks that are available.
I personally keep the done_dialog on the same line as "accept". It's easier for me to follow...
Try this (untested)
..."(setq str (control_accept $data))(done_dialog 1)"
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
pbejse
Message 3 of 6 (1,030 Views)
09-17-2012 06:06 PM in reply to: scot-65
I concur...
Moshe-A
Message 4 of 6 (1,019 Views)
09-18-2012 12:38 AM in reply to: scot-65
Hi Scot,
thank you very much for your help.
i expand a little of what i'm doing:
suppose in main function i have a registry key and a file name
(that were build in main and ofcourse defined as locals) as the user picks th OK button
i need them in the (ctrl_accept) callback function to write the file name to registry.
all of that include some error cheaking could not be done from (action_tile) call
i suppose you agree with me?!
the problem arise in buttons i use and edit_box tiles.
this code is a small example of my program
(defun ctrl_accept (data / rkey filename)
 (setq rkey (eval (car (read data)))
 (setq filename (eval (cadr (read data))))
 (if (vl-registry-read rkey)
  (vl-registry-write rkey "datafilename" filename)
 (done_dialog 1)
(defun c:main (/ rkey filename dcl_id what_next)
 (setq rkey (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications")
       rkey (strcat rkey "\\AppName")
 (if (not (vl-registry-read rkey))
  (vl-registry-write rkey)
 (setq filename "appdata.txt")
 (setq dcl_id (ai_dcl "appdata")); load dcl file
 (setq what_next 3)
 (While (> what_next 1)
  (if (not (new_dialog "app_dialog" dcl_id "" '(-1 -1))); open dialog
   (exit)
  (client_data_tile "accept" "(rkey filename)")
  (SetQ what_next (start_dialog)); start dialog
 ); while
 (princ)
as i said earlier the problem is not steady it arise from time to time
but i can not relay on it.
Moshe
Moshe-A
Message 5 of 6 (1,012 Views)
09-18-2012 02:11 AM in reply to: scot-65
Scot,
thanks
Moshe
scot-65
Message 6 of 6 (996 Views)
09-18-2012 04:04 PM in reply to: Moshe-A
I'm not sure what is "client_data_tile"?
It's not set_tile, mode_tile, or action_tile.
Getting past that, what is "(rkey filename)"? Looks like a call to a subroutine?
If you want the gremlin to remain inside a program, yet still have access to that
gremlin while inside a function (subroutine) restructure your program as follows:
(defun c:MAIN ( / a b c...)
 (defun SUB1 (f g / h k...) ... ) ;a b c f and g can be seen inside here, h and k is local to SUB1.
 (defun SUB2 (m / n...) ... ) ;again, a b c and m can be seen inside here, n is local to SUB2.
 (princ)
);end MAIN
One might have conflicts with declared variables (gremlins) for this structure above.
I have used a suffix "1", "2", etc. inside my subs, especially with numbers or counters
(sslength, setq n1, etc.).
TDINDWG Time Display in Drawing I looked at once upon a time,
but never investigated the other one (is it a Dunsel variable???).
We use UNNAMED profiles here. It serves us no purpose(?).
Scot-65
