Hello
I'm having problems configuring the visual lisp editor in AutoCAD 2011/2012 x64. When I try to configure the color screen appears as attached file and are generated the following errors:
error: Exception occurred: 0xC0000094
warning: unwind skipped on exception
Machine settings
Asus Motherboard
AMD X6 II
8GB memory
Video ATI Radeon 5750 1GB
Would someone help me solve this problem.
Hi there,
As you've noticed, the visual lisp config dialog doesn't work properly on x64 based machines. The editor does work on an x86 based machine though. You can setup your config on an another installation of AutoCAD and copy the vlide.dsk file from that machine to your x64 install. I have used vlisp config files from AutoCAD 2006 on Autocad 2012 no problem.
Take a look at http://www.geospecialling.com/index.php/2011/08/hacking-visual-lisp-ide-to-be-a-little-more-awesome/ - I recently documented my experiences with this problem here and went into a lot more detail on how to edit the config file manually if needed.
darrin
