dhaverstick
Message 1 of 5 (300 Views)
Problem Getting AcadBlockReference Object
300 Views, 4 Replies
10-25-2004 07:03 AM
Has anyone else had problems getting an AcadBlockReference object by setting it this way: Set AcadBlockRef = ModelSpaceObj.Item("AcadBlockRefName") where "AcadBlockRefName" is the name of the block reference object. Sometimes this method works and sometimes it doesn't. The only way I can get the BlockRef object 100% of the time is by iterating through all the items in Modelspace like this
For Each EntityObj in ModelSpaceObj
If TypeOf EntityObj is AcadBlockReference Then
Set AcadBlockRef = EntityObj
If AcadBlockRef.Name = "AcadBlockRefName" Then
Exit For
Endif
Next
Darren
*Tony Tanzillo
Message 2 of 5 (300 Views)
Re: Problem Getting AcadBlockReference Object
10-25-2004 07:08 AM in reply to: dhaverstick
Where did you get the idea that the Item method accepts the name of a block reference? It doesn't. Common sense would suggest that since there can be more than one insertion of a block of a given name, that you could not use the name as an index key. -- http://www.caddzone.com AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005 http://www.acadxtabs.com "dhaverstick" wrote in message news:9442839.1098713061273.JavaMail.jive@jiveforum1.autodesk.com... > Has anyone else had problems getting an AcadBlockReference object by > setting it this way: Set AcadBlockRef = > ModelSpaceObj.Item("AcadBlockRefName") where "AcadBlockRefName" is the > name of the block reference object. Sometimes this method works and > sometimes it doesn't. The only way I can get the BlockRef object 100% of > the time is by iterating through all the items in Modelspace like this > For Each EntityObj in ModelSpaceObj > If TypeOf EntityObj is AcadBlockReference Then > Set AcadBlockRef = EntityObj > If AcadBlockRef.Name = "AcadBlockRefName" Then > Exit For > Endif > Next > > > Thanks, > > Darren
*Jason Piercey
Message 3 of 5 (300 Views)
10-25-2004 08:07 AM in reply to: dhaverstick
In addition to any replies you might receive or already received, you may find more information or responses by posting future VBA related questions in the following discussion group: By NNTP discussion group reader at news://discussion.autodesk.com/autodesk.autocad.customization.vba By HTTP (web-based) interface at http://discussion.autodesk.com/forum.jspa?forumID=33 -- Autodesk Discussion Group Facilitator "dhaverstick" wrote in message news:9442839.1098713061273.JavaMail.jive@jiveforum1.autodesk.com... > Has anyone else had problems getting an AcadBlockReference object by setting it this way: Set AcadBlockRef = ModelSpaceObj.Item("AcadBlockRefName") where "AcadBlockRefName" is the name of the block reference object. Sometimes this method works and sometimes it doesn't. The only way I can get the BlockRef object 100% of the time is by iterating through all the items in Modelspace like this > For Each EntityObj in ModelSpaceObj > If TypeOf EntityObj is AcadBlockReference Then > Set AcadBlockRef = EntityObj > If AcadBlockRef.Name = "AcadBlockRefName" Then > Exit For > Endif > Next > > > Thanks, > > Darren
dhaverstick
Message 4 of 5 (300 Views)
10-25-2004 09:17 AM in reply to: dhaverstick
1) In my particular case, all block reference objects have unique names. 2) I got the idea of setting object references using the Item method from this discussion group. I tried it and it worked in my test case.
*Doug Broad
Message 5 of 5 (300 Views)
10-25-2004 10:21 AM in reply to: dhaverstick
You can use the name form of the item method on the block collection but I am sure the name form does not work in the modelspace collection. Why not use filtered selection sets? Regards, Doug "dhaverstick" wrote in message news:15958284.1098721080141.JavaMail.jive@jiveforum1.autodesk.com... > 1) In my particular case, all block reference objects have unique names. 2) I got the idea of setting object references using the Item method from this discussion group. I tried it and it worked in my test case.
