Good night, you can print text in word by princ command with font formatting and size.
thank you: Marcelo
Solved by hgasty1001. Go to Solution.
Short answer, NO, all the printing functions in Autolisp are just simple ASCII character printing without information about font or format. If you need to create a word document from Autolisp yo can use Office Open XML format, some info here: Word files . Also you can try unzipping a .docx word document (just use pkzip or any other zip application) and take a look to the format and XML schema, the same apply to Excel.
Gaston Nunez
