I have a custom linetype that's just a series of arrows I want to use to show the flow of a ditch. I've played around with this thing for a while and have these dots at each end of the line that shows up when I print.
Is there any way to make this linetype without the dots at each end?
I've attached a screen shot, and the actual files for the line type.
FLOW.lin
*FLOW, A,0,-.002,.148519,[FLOW,FLOW.shx,s=1],-.449481
@ArchD wrote:I have a custom linetype that's just a series of arrows I want to use to show the flow of a ditch. I've played around with this thing for a while and have these dots at each end of the line that shows up when I print.
I don't think so. From the Customization Guide:
When the linetype is drawn, AutoCAD uses the first pattern descriptor for the starting and ending dashes. Between the starting and ending dashes, the pattern dash specifications are drawn sequentially, beginning with the second dash specification and restarting the pattern with the first dash specification when required.
A-type alignment requires that the first dash length be 0 or greater (a pen-down segment).
It's that 0-length pen-down segment at the beginning of your pattern description that you're seeing at the ends.
If you don't mind having a line segment without an arrowhead at the arrowhead-ward ends of things, you can do that. The result will go all the way to the ends of the object, rather than have the gaps between the arrow portions and the points at the ends that you're getting, but at least it won't have points separated from the rest at the ends. I have a similar linetype that works that way, though it uses a > text character instead of a shape [see attached]. If that will work for you, I think you could just omit the 0 and the first negative descriptor from your pattern.
Adjust your code to what is shown below except for the shape info. Also see attached. I agree with Kent on the subject of haveing the 0 at the beginning of the linetype code. HTH
*ARRW,ARRW ----<----<----
A,.2,-.25,[ARWW,HRH-Ltshp,s=.0125],-.1,.1
Great! I can use it with the line on the end, I'll just have to add an arrow head. This option beats copying tons of little arrows around and rotating them. Even though I do have a dynamic block for that, it's time consuming.
Thanks for the help you guys. My final ended up being:
*FLOW, A,.2,.1,[FLOW,FLOW.SHX,s=2],-2,.125
Your welcome, you helped me on a ribbon issue some time ago, so its nice to be able to return the favor, not that we're counting here. Have a good one.
Ha, nice, glad I could help on the ribbon issue. That's what I come here for, usually great people willing to help. Thanks again.
I'll mark this as a win for you on my wall here at my office.
That works. I don't really know what the part of that snipet of code really do, I just mess around with them and hope it looks good.
Sometimes, the beginning and ending line ends up being longer than I'd like. Is there a way to make it so that they will only get so long?
@ArchD wrote:....
Come to think of it, my suggestion to combine your .2 and .1 descriptors may not have been the best idea, because of what it says in the Help excerpt [that I myself quoted], about the first descriptor being used for the beginning and end dashes. I expect that if you broke the .3 apart again, and reversed the two piece, with .1 followed by .2, you'd get shorter ends. You might even start with a 0-length pen-down descriptor as you had originally, but just follow it with another pen-down descriptor instead of a pen-up, such as:
A,0,.3,[FLOW....
which probably would minimize the end lengths, since that 0 should be used for the end dash length.
