Iv been trying to change the below lisp (unsucessfully) to add a prefix to an attribute with tag "PARTNUMBER" in a bunch of blocks. The routine i found online somewhere and is perfect but it adds the prefix/suffix to all attributes. Can someone help with adding the missing parts which select the attribute i need to change. Many thanks
(defun c:test ( / as el en i ss str typ ) (initget "Prefix Suffix") (setq typ (cond ((getkword "\nAdd Prefix or Suffix? [Prefix/Suffix] <Prefix>: ")) ("Prefix"))) (setq str (getstring t (strcat typ " to Add: "))) (if (setq ss (ssget '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength ss)) (setq en (ssname ss (setq i (1- i)))) (while (eq "ATTRIB" (cdr (assoc 0 (setq el (entget (setq en (entnext en))))))) (setq as (cdr (assoc 1 el))) (if (eq "Prefix" typ) (if (not (wcmatch as (strcat str "*"))) (entmod (subst (cons 1 (strcat str as)) (assoc 1 el) el)) ) (if (not (wcmatch as (strcat "*" str))) (entmod (subst (cons 1 (strcat as str)) (assoc 1 el) el)) ) ) ) ) ) (princ) )
Solved by Lee_Mac. Go to Solution.
I recognise that code
Try the following modification:
(defun c:test ( / ent enx exs fun idx pat sel str typ ) (initget "Prefix Suffix") (setq typ (cond ((getkword "\nAdd Prefix or Suffix? [Prefix/Suffix] <Prefix>: ")) ("Prefix")) str (getstring t (strcat "\n" typ " to add: ")) ) (if (= "Prefix" typ) (setq pat (strcat "~" str "*") fun (lambda ( x ) (strcat str x)) ) (setq pat (strcat "~*" str) fun (lambda ( x ) (strcat x str)) ) ) (if (setq sel (ssget '((0 . "INSERT") (66 . 1)))) (repeat (setq idx (sslength sel)) (setq ent (entnext (ssname sel (setq idx (1- idx)))) enx (entget ent) ) (while (= "ATTRIB" (cdr (assoc 0 enx))) (if (and (= "PARTNUMBER" (cdr (assoc 2 enx))) (wcmatch (cdr (setq exs (assoc 1 enx))) pat)) (entmod (subst (cons 1 (fun (cdr exs))) exs enx)) ) (setq ent (entnext ent) enx (entget ent) ) ) ) ) (princ) )
Lee
You're very welcome Daniel.
