Visual LISP, AutoLISP and General Customization
precision distance and slop lisp
11 REPLIES 11
Message 1 of 12
zasanil
902 Views, 11 Replies
I'm looking for a lisp file that would perform the same function as the DI (DIST) comand but use the maximum percision autocad can display (16 decimal places?). Is there an easy way to do this?
Dan
Dan Nicholson C.I.D.
PCB Design Engineer
Tags (2)
11 REPLIES 11
Message 2 of 12
marko_ribar
in reply to: zasanil
(defun c:dii ( / p1 p2 )
  (while (not p1) (setq p1 (getpoint "\nPick or specify start point : ")))
  (while (not p2) (setq p2 (getpoint p1 "\nPick or specify end point : ")))
  (princ (rtos (distance p1 p2) 2 50))
  (princ)
 HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 12
zasanil
in reply to: marko_ribar
Hi Marko,
That worked great for a single distance, but would you be able to add all 3 cordinate values and angles from point to point like the DIST command does?
The output it normally gives is like this:
Distance = 1.8762,  Angle in XY Plane = 8,  Angle from XY Plane = 0
Delta X = 1.8595,  Delta Y = 0.2499,   Delta Z = 0.0000
I would like the same info, but with the max precision for all the values (distance, deltas & angles) like you did with the single value.
Thanks!
PCB Design Engineer
Message 4 of 12
marko_ribar
(defun c:dii ( / p1 p2 d dx dy dz v dxw dyw dzw w ax vprim vprimd axy )
  (setq d (distance p1 p2))
  (setq dx (car (setq v (mapcar '- p2 p1))))
  (setq dy (cadr v))
  (setq dz (caddr v))
  (setq dxw (car (setq w (mapcar '- (trans p2 1 0) (trans p1 1 0)))))
  (setq dyw (cadr w))
  (setq dzw (caddr w))
  (setq ax (cvunit (atan dy dx) "radians" "degrees"))
  (setq vprim (list (car v) (cadr v) 0.0))
  (setq vprimd (distance '(0.0 0.0 0.0) vprim))
  (setq axy (cvunit (atan (caddr v) vprimd) "radians" "degrees"))
  (prompt "\nDistance : ")(princ (rtos d 2 50))
  (prompt "\n\nDX in UCS : ")(princ (rtos dx 2 50))
  (prompt "\nDY in UCS : ")(princ (rtos dy 2 50))
  (prompt "\nDZ in UCS : ")(princ (rtos dz 2 50))
  (prompt "\n\nDX in WCS : ")(princ (rtos dxw 2 50))
  (prompt "\nDY in WCS : ")(princ (rtos dyw 2 50))
  (prompt "\nDZ in WCS : ")(princ (rtos dzw 2 50))
  (prompt "\n\nAngle around Z axis from X axis as 0.0 degree reference : ")(princ (rtos ax 2 50))(prompt " degrees")
  (prompt "\nAngle of picked points vector to XY plane : ")(princ (rtos axy 2 50))(prompt " degrees")
  (princ)
 HTH, M.R.
Message 5 of 12
Lee_Mac
Here's another way to write it:
(defun c:dd ( / atos ntos p q v )
    (setq ntos (lambda ( x ) (rtos   x (getvar 'lunits) 16))
          atos (lambda ( x ) (angtos x (getvar 'aunits) 16))
    (if (and (setq p (getpoint "\nSpecify 1st point: "))
             (setq q (getpoint "\nSpecify 2nd point: " p))
             (setq v (mapcar '- q p))
        (prompt
            (strcat
                "\nDistance = "            (ntos (distance p q))
                ", Angle in XY Plane = "   (atos (angle p q))
                ", Angle from XY Plane = " (atos (atan (last v) (distance '(0.0 0.0) v)))
                "\nDelta X = " (ntos (car v)) ", Delta Y = " (ntos (cadr v)) ", Delta Z = " (ntos (caddr v))
    (princ)
Message 6 of 12
stevor
From Ribar's start, adding old code, try this.
Remove commented lines,or others,
change AngToS  to RTOS, reolutions,
make variables local, etc, as needed.
 (defun c:dii ( / os) ; Marko Ribar 10-04-2014, +  p1 p2
  (setq RSD 16  ; 50  Real To String Dimension  000 000 000 000 000
        osm (getvar 'osmode)) (princ " Osnap: ")(prin1 osm)
 ;(or (and (setq p1 (get_P P1 "\n Start pt: "))
 ;  (setq p2 (get_P P2 "\n End pt: "))) (EXIT_S"\n NO Pts "))
  (setq p1x (car p1)  p1y (cadr p1)  p1z (caddr p1))  ;
  (setq p2x (car p2)  p2y (cadr p2)  p2z (caddr p2))  ;
  (setq dx (- p2x p1x)  dy (- p2y p1y)  dz (- p2z p1z) )  ; 2-1,
  ; (princ"\n P1: ")(prin1 P1) (princ",  P2: ")(prin1 P2)
  (redraw) (grdraw p1 (list p2x p1y p1z) 1)
  (grdraw (list p2x p1y p1z) (list p2x p2y p1z) 2)
  (grdraw (list p2x p2y p1z) p2 3)
  ; Angle in XY:  resolve sine DY/DX for X=0, let Acad do it
  (setq Axy (angle '(0 0 0) (list dx dy 0 )))
  ; same if DX=0 and DY=0
  (SETQ DXY (DISTANCE '(0 0) (list dx dy)) )
  (setq Az (angle '(0 0) (list DXY dz )) )
  (princ"\n Dist: ")(princ (rtos (distance p1 p2) 2 RSD))
  ;(princ",  Axy: ")(princ (rtos Axy 2 RSD))
  ;(princ",  Az: ")(princ (rtos Az 2 RSD))  (princ " radians ")
  (princ",  Axy: ")(princ (ANGtos Axy 0 RSD))
  (princ",  Az: ")(princ (ANGtos Az 0 RSD)) (princ " degrees ")
  (princ"\n DX: ")(princ (rtos DX 2 RSD))
  (princ",  DY: ")(princ (rtos DY 2 RSD))
  (princ",  DZ: ")(princ (rtos DZ 2 RSD))
  (princ) ) ; def
S
Message 7 of 12
zasanil
Thank you all! These solutions all work great.
/cheers
PCB Design Engineer
Message 8 of 12
marko_ribar
Lee, this line of your code is wrong...
It should be :
 ", Angle from XY Plane = " (atos (atan (last v) (distance '(0.0 0.0) (list (car v) (cadr v)))))
Regards, M.R.
Message 9 of 12
Lee_Mac
It should be :
No, the line is correct as it is.
Lee
Message 10 of 12
marko_ribar
in reply to: Lee_Mac
So if one point is specified as 2D, distance will calculate 2D distance... You are right, but my observation was more apparent...
Message 11 of 12
zasanil
I have a related question about a keyboard shortcut for this lisp. I created a keyboard shortcut in the CUI window and assigned a keyboard shortcut of SHIFT-D to the command with a macro of ^c^cdii. When I'm in the main window and hit the SHIFT-D to activate the lisp, it pops up the window to ask for the first point, but the focus is moved from the cursor to the textbox where you can type in the point coords. In that textbox it writes the letter D. How do I make it switch focus back to the cursor where I can pick a point with the mouse automatically? Do I have to change the macro command somehow?
edited to fix typos
PCB Design Engineer
Message 12 of 12
stevor
Since all the examples seem to use getpoint, try bypassing the Shift-D thing, and use the defined command symbols: C:DDI or C:DD.
S
”Boost
