I'm looking for a lisp file that would perform the same function as the DI (DIST) comand but use the maximum percision autocad can display (16 decimal places?). Is there an easy way to do this?
Dan
Solved by stevor. Go to Solution.
Solved by Lee_Mac. Go to Solution.
Solved by marko_ribar. Go to Solution.
(defun c:dii ( / p1 p2 ) (while (not p1) (setq p1 (getpoint "\nPick or specify start point : "))) (while (not p2) (setq p2 (getpoint p1 "\nPick or specify end point : "))) (princ (rtos (distance p1 p2) 2 50)) (princ) )
HTH, M.R.
Hi Marko,
That worked great for a single distance, but would you be able to add all 3 cordinate values and angles from point to point like the DIST command does?
The output it normally gives is like this:
Distance = 1.8762, Angle in XY Plane = 8, Angle from XY Plane = 0
Delta X = 1.8595, Delta Y = 0.2499, Delta Z = 0.0000
I would like the same info, but with the max precision for all the values (distance, deltas & angles) like you did with the single value.
Thanks!
(defun c:dii ( / p1 p2 d dx dy dz v dxw dyw dzw w ax vprim vprimd axy ) (while (not p1) (setq p1 (getpoint "\nPick or specify start point : "))) (while (not p2) (setq p2 (getpoint p1 "\nPick or specify end point : "))) (setq d (distance p1 p2)) (setq dx (car (setq v (mapcar '- p2 p1)))) (setq dy (cadr v)) (setq dz (caddr v)) (setq dxw (car (setq w (mapcar '- (trans p2 1 0) (trans p1 1 0))))) (setq dyw (cadr w)) (setq dzw (caddr w)) (setq ax (cvunit (atan dy dx) "radians" "degrees")) (setq vprim (list (car v) (cadr v) 0.0)) (setq vprimd (distance '(0.0 0.0 0.0) vprim)) (setq axy (cvunit (atan (caddr v) vprimd) "radians" "degrees")) (prompt "\nDistance : ")(princ (rtos d 2 50)) (prompt "\n\nDX in UCS : ")(princ (rtos dx 2 50)) (prompt "\nDY in UCS : ")(princ (rtos dy 2 50)) (prompt "\nDZ in UCS : ")(princ (rtos dz 2 50)) (prompt "\n\nDX in WCS : ")(princ (rtos dxw 2 50)) (prompt "\nDY in WCS : ")(princ (rtos dyw 2 50)) (prompt "\nDZ in WCS : ")(princ (rtos dzw 2 50)) (prompt "\n\nAngle around Z axis from X axis as 0.0 degree reference : ")(princ (rtos ax 2 50))(prompt " degrees") (prompt "\nAngle of picked points vector to XY plane : ")(princ (rtos axy 2 50))(prompt " degrees") (princ) )
HTH, M.R.
Here's another way to write it:
(defun c:dd ( / atos ntos p q v ) (setq ntos (lambda ( x ) (rtos x (getvar 'lunits) 16)) atos (lambda ( x ) (angtos x (getvar 'aunits) 16)) ) (if (and (setq p (getpoint "\nSpecify 1st point: ")) (setq q (getpoint "\nSpecify 2nd point: " p)) (setq v (mapcar '- q p)) ) (prompt (strcat "\nDistance = " (ntos (distance p q)) ", Angle in XY Plane = " (atos (angle p q)) ", Angle from XY Plane = " (atos (atan (last v) (distance '(0.0 0.0) v))) "\nDelta X = " (ntos (car v)) ", Delta Y = " (ntos (cadr v)) ", Delta Z = " (ntos (caddr v)) ) ) ) (princ) )
From Ribar's start, adding old code, try this.
Remove commented lines,or others,
change AngToS to RTOS, reolutions,
make variables local, etc, as needed.
(defun c:dii ( / os) ; Marko Ribar 10-04-2014, + p1 p2
(setq RSD 16 ; 50 Real To String Dimension 000 000 000 000 000
osm (getvar 'osmode)) (princ " Osnap: ")(prin1 osm)
;(or (and (setq p1 (get_P P1 "\n Start pt: "))
; (setq p2 (get_P P2 "\n End pt: "))) (EXIT_S"\n NO Pts "))
(setq p1x (car p1) p1y (cadr p1) p1z (caddr p1)) ;
(setq p2x (car p2) p2y (cadr p2) p2z (caddr p2)) ;
(setq dx (- p2x p1x) dy (- p2y p1y) dz (- p2z p1z) ) ; 2-1,
; (princ"\n P1: ")(prin1 P1) (princ", P2: ")(prin1 P2)
(redraw) (grdraw p1 (list p2x p1y p1z) 1)
(grdraw (list p2x p1y p1z) (list p2x p2y p1z) 2)
(grdraw (list p2x p2y p1z) p2 3)
; Angle in XY: resolve sine DY/DX for X=0, let Acad do it
(setq Axy (angle '(0 0 0) (list dx dy 0 )))
; same if DX=0 and DY=0
(SETQ DXY (DISTANCE '(0 0) (list dx dy)) )
(setq Az (angle '(0 0) (list DXY dz )) )
(princ"\n Dist: ")(princ (rtos (distance p1 p2) 2 RSD))
;(princ", Axy: ")(princ (rtos Axy 2 RSD))
;(princ", Az: ")(princ (rtos Az 2 RSD)) (princ " radians ")
(princ", Axy: ")(princ (ANGtos Axy 0 RSD))
(princ", Az: ")(princ (ANGtos Az 0 RSD)) (princ " degrees ")
(princ"\n DX: ")(princ (rtos DX 2 RSD))
(princ", DY: ")(princ (rtos DY 2 RSD))
(princ", DZ: ")(princ (rtos DZ 2 RSD))
(princ) ) ; def
Lee, this line of your code is wrong...
It should be :
", Angle from XY Plane = " (atos (atan (last v) (distance '(0.0 0.0) (list (car v) (cadr v)))))
Regards, M.R.
It should be :
No, the line is correct as it is.
Lee
So if one point is specified as 2D, distance will calculate 2D distance... You are right, but my observation was more apparent...
I have a related question about a keyboard shortcut for this lisp. I created a keyboard shortcut in the CUI window and assigned a keyboard shortcut of SHIFT-D to the command with a macro of ^c^cdii. When I'm in the main window and hit the SHIFT-D to activate the lisp, it pops up the window to ask for the first point, but the focus is moved from the cursor to the textbox where you can type in the point coords. In that textbox it writes the letter D. How do I make it switch focus back to the cursor where I can pick a point with the mouse automatically? Do I have to change the macro command somehow?
edited to fix typos
