Visual LISP, AutoLISP and General Customization
POPUP_LIST DEFAULT
2 REPLIES 2
trathbun
162 Views, 2 Replies
POPUP_LIST DEFAULT
I have a lisp program which contains a popup_list to select from a list of layers. What I would like to know - is there a way to set a particular layer as the default rather than having the first layer in the list always displayed.
Tim Rathbun
2 REPLIES 2
kozmos
in reply to: trathbun
(start_list "popup_list")
(mapcar 'add_list LayerList)
(end_list)
(set_tile "popup_list" (itoa (vl-position LayerName LayerList)))
Tim, Look at the free downloads area in our TechCenter web-site (see URL in the sig below). In the Dialog Box library, there is a routine called DL_SelectProperty that does a neat job of showing up a list of strings in a list box and also allows multiple or single selection, sorted or un-sorted, with or without defaults. You could use this as a replacement for your popup list if you wish and more importantly, it shows how these stuff are programmed. Regards Rakesh trathbun wrote: > I have a lisp program which contains a popup_list to select from a list of layers. What I would like to know - is there a way to set a particular layer as the default rather than having the first layer in the list always displayed. > > Thanks, > Tim Rathbun -- Please email me your replies. I may not always be observing the posts here. AutoCAD customization for Engineering/Mapping/GIS Get GeoTools @ http://www.4d-technologies.com/geotools Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm FREE downloads : http://www.4d-technologies.com/techcenter
”Boost
