polylines in arx
6 REPLIES 6
881 Views, 6 Replies
polylines in arx
how can I draw a polyline that consists of two arcs and to straight line in
an ARX program..........I am using 2000 I will need to extrude this entity
when done.
thanks in advance
6 REPLIES 6
One mor note..........I can draw these in regular lines if it might be
easier to explain how to change them to a pline
"Rob" wrote in message
news:D3D8C8E0481DE6503E0B670028806EFD@in.WebX.maYIadrTaRb...
in
entity
> when done.
> thanks in advance
AcDbPolyline *pPline = new AcDbPolyline();
// for the line segments
pPline->addVertexAt(0, AcGePoint2d(0,0));
pPline->addVertexAt(1, AcGePoint2d(5,5));
// for the curve
pPline->addVertexAt(2, AcGePoint2d(10,5), 0.5); // .5 is the "bulge factor"
pPline->addVertexAt(3, AcGePoint2d(20,10));
etc...
then...
AcDbBlockTable *pTable;
AcDbBlockTableRecord *pBTR;
acdbHostApplicationService()->workingDatabase()->getBlockTable(pTable,
AcDb::kForRead);
pTable->getAt(ACDB_MODEL_SPACE, pBTR, AcDb::kForWrite);
pTable->close();
pBTR->appendAcDbEntity(pPline);
pBTR->close();
pPline->close();
Tada....
Read through the example problems and online help that ship with the SDK -
they're wonderful!
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
Im gonna need to to this with 3d points-------is there away to convert the
lines I have drawn to a pline??
Thanks for the info
"Jon Rizzo" wrote in message
news:5554B82837958DF459C16C7628558FC6@in.WebX.maYIadrTaRb...
> // for the curve
factor"
> etc...
> then...
> AcDb::kForRead);
> pTable->close();
> pBTR->close();
> pPline->close();
> Tada....
> they're wonderful!
> Jon Rizzo
well, an AcDbPolyline is a 2d object, so you have to give it 2d points.
you can draw an AcDb3dPolyline using 3d points, but they cannot have arc
segments. If I am not mistaken, you can't extrude a 3d polyline, either...
Jon Rizzo
news:131DCC0125B7B651F9649EC6DDD36FEE@in.WebX.maYIadrTaRb...
> Thanks for the info
> > // for the curve
> factor"
> > etc...
> > then...
> > AcDb::kForRead);
> > pTable->close();
> > pBTR->close();
> > pPline->close();
> > Tada....
SDK -
> > they're wonderful!
> > Jon Rizzo
>Thanks for the info
You can only set the elevation of the polyline, not a specific Z value
for each vertex.
Use the setElevation(double z); to set a Z value for all vertecies.
// Anders
hi all,
"you can draw an AcDb3dPolyline using 3d points, but they cannot have arc segments. If I am not mistaken, you can't extrude a 3d polyline, either..."
Your first afirmation is right you can't have an arc in a 3d Polyline
But your Second is wrong : Autocad allow to extrud along a 3d polyline 🙂
Enjoy,
Aymeric
”Boost
