Visual LISP, AutoLISP and General Customization
polyline join macro
8 REPLIES 8
Message 1 of 9
allywhite666
2116 Views, 8 Replies
polyline join macro
Hello I am trying to create a macro that will join some polylines with different elevations.
The routine I use is
pedit>
M (multiple)>
J (join)
0 (fuzz distance)
this usually joins the lines
So I tried using this macro
^C^C_pedit;m;j;0;;
I am not experienced with macro's, what am I doing wrong?
8 REPLIES 8
Message 2 of 9
Kent1Cooper
in reply to: allywhite666
pedit>
M (multiple)>
J (join)
0 (fuzz distance)
^C^C_pedit;m;j;0;;
You need to have something in there for object selection:
^C^C_pedit;m;\j;0;;
Kent Cooper, AIA
Message 3 of 9
allywhite666
in reply to: Kent1Cooper
Hello Kent,
I added the \ but this gives the same result as the original.
This is what it does
it runs pedit and I can select the lines but it stops at the options where I want it to join and I have to enter J, I want it to automatically enter J and keep going.
Message 4 of 9
Kent1Cooper
A possibility -- is your PEDITACCEPT System Variable set to 1?  If not, there can be an additional prompt in the command.
Kent Cooper, AIA
Message 5 of 9
hmsilva
 Hi Alli,
in addition to Kent1Cooper advices, you can use something like this:
^C^C_PEDITACCEPT;1;_pedit;m;\\;j;0;;
The '\' in a macro, means one pause, the above macro only allows to select two objects by pick, or multiple objects by one window/crossing.
Another way will be to add an asterisk at the macro beginning
*^C^C_PEDITACCEPT;1;_pedit;m;\\;j;0;;
the '*'in a macro, will repeat the macro until the user select another command or press escape.
Please note that you only need to set PEDITACCEPT once, so it may be preferable to add to your 'acaddoc.lsp' a text line with
(setvar 'PEDITACCEPT 1)
If you are not on LT, you possibly should think in a AutoLISP routine,
e.g.
(defun c:MyPedit (/ paccept ss)
  (if (setq ss (ssget "_:L"))
    (progn
      (setq paccept (getvar 'PEDITACCEPT))
      (command "_.pedit" "_M" ss "" "_J" 0.0 "")
      (setvar 'PEDITACCEPT paccept)
  (princ)
Save the file as "YourLispFileName.lsp" in one Support File Search Path, and in the macro just something like
(if (not c:MyPedit)(load "YourLispFileName"));MyPedit;
Hope that helps
Henrique
Message 6 of 9
Kent1Cooper
in reply to: hmsilva
Correct -- I was getting my selection options mixed up.  There is a way, which I had in mind but didn't get right, to use only one backslash for the User to select any number of objects, including windows [crossing or otherwise], removals, etc.  It is by way of the SELECT command [which will let you play around with all selection options under the force of one backslash] and then use the Previous option for the Selection inside the PEDIT command:
^C^C_.SELECT \_.PEDIT _M _P ;J 0 ;
[Also include forcing PEDITACCEPT first if you need to, add the asterisk for automatic repetition if you like, etc.]
Kent Cooper, AIA
Message 7 of 9
hmsilva
Nice!
Henrique
Message 8 of 9
allywhite666
Thank you both for your help, the command
is what I wanted to achieve, great work Kent.
Message 9 of 9
Although it has been some time since this question has seen any action I am in a similar situation so I figured I would give it a shot as the information that comes from it may help other folks in a similar situation:
I would like to incorporate a JOIN polyline operation on the right-click shortcut EDIT Menu.
Setup:
-Objects already selected
-Pedt Accept sysvar already set to 1
Right Click >> Select PJoin (defined macro)
In the CUI Shortcut,>> Edit Menu I have tried
^C^C_.SELECT \_.PEDIT _M _P ;J 0 ;  Along with many variations but I cannot get the process to work
properly.
The goal is to have the objects selected >> Toggle the P Join Operation and have it perform the operation with a default predefined fuzz distance of say .001
If someone has the time could you offer some guidance on this?
Thanks in Advance
-Tim C.
”Boost
