Visual LISP, AutoLISP and General Customization
Pneumatic Linetype ???
22 REPLIES 22
Message 1 of 23
11518 Views, 22 Replies
How come there isn't a pneumatic linetype? This is one of the most commonly used linetypes in controls and instrumentation engineering drawings!!! Someone please tell me why? And how can I obtain it without manually doing it myself?
22 REPLIES 22
Message 2 of 23
what's it look like?
wrote in message news:5788884@discussion.autodesk.com...
it myself?
Message 3 of 23
solid line with 2 diagonal lines spaced every so often ... similar to above.
Message 4 of 23
If you have Express Tools, it is relatively simple to MKSHAPE and MKLTYPE
Gordon
wrote in message news:5788892@discussion.autodesk.com...
Message 5 of 23
Try this. Place in your acad.lin file.. or make up a new
.lin file called pneumatic.lin.
*PNEUMATIC,Pneumatic Lines
A,.25,-.12,.25,-.12,.25,-.12,["//",STANDARD,S=.20,R=0.0,X=-0.1,Y=-.10],-.25
Watch for line wrap.
Bob
Message 6 of 23
dgorsman
Rather than relying on text, use the "slash" shape in the shape file that comes with AutoCAD. Fewer problems, especially given some peoples prediliction to using text style Standard.
Message 7 of 23
Or, with solid lines...
*PNEUMATIC2,Pneumatic Lines
A,.75,-.25,["//",STANDARD,S=.20,R=0.0,X=-0.1,Y=-.10],-.25
Bob
Message 8 of 23
Alrighty. Let's see your version.
Bob
Message 9 of 23
dgorsman
[TRACK1,ltypeshp.shx,S=___,R=-45,X=0,Y=0]
Adjust scale and position to fit.
Message 10 of 23
I tried that one.
Had to change to:
*PNEUMATIC3,Pneumatic Lines
A,.75,-.25,[TRACK1,ltypeshp.shx,S=.25,R=-45,X=0,Y=0],-.25
and, that only gives me just (1) slash..
Did you check it ?
Bob
Message 11 of 23
dgorsman
Needs to be repeated for each slash - really busy here, so I grabbed the binary signal version by mistake, sorry... but on the plus side, fiddling with it should give you a better feel on how its put together.
Message 12 of 23
Here is what I ended up using after a few trials. This gives the double hash mark.
*PNEUMATIC,Pneumatic Lines ----//----//----//----//
A,1.2,-.01,[TRACK1,ltypeshp.shx,S=.15,R=-45,X=0,Y=0],-.2,[TRACK1,ltypeshp.shx,S=.15,R=-45,X=0,Y=0],-.01
Steve Cook
Cook Process Solutions, LLC
Message 13 of 23
Brilliant, thanks - just saved me a stack of time Smiley Very Happy
Message 14 of 23
Pabber
Is there a way to have AutoCAD draw a line between the slashes (no gap)?
Thanks!
Message 15 of 23
Kent1Cooper
in reply to: Pabber
Thanks!
Just take the minus signs out [and you may as well take the ,-.01 out altogether].
Kent Cooper, AIA
Message 16 of 23
Pabber
in reply to: dgorsman
It still has a gap between the slashes. I assume that it's because the second slash is drawn offset from the first slash producing a visible gap...
Message 17 of 23
dgorsman
in reply to: Pabber
If you want a single, very thick slash then you will have to stack several very close to each other and let the plotted lineweight merge them together, or build a specific shape.  Just don't forget to distribute the compiled shape file or face the wrath of those who inherit your DWGs.
Message 18 of 23
Kent1Cooper
in reply to: Pabber
Sorry....  I thought you meant you wanted no gap in the through-it-all line -- it's the minus signs that cause that [the "pen up" portions] -- rather than no gap between the slashes.  You can go with dgorsman's suggestions, or ir .TTF fonts are viable in complex linetypes [I haven't tried them], maybe you can use some character from Wingdings, or a rotated "pipe" or underscore or capital I in Swiss, or something.
Kent Cooper, AIA
Message 19 of 23
Pabber
Please see the image below.
Red is NOT what I'm after
Green IS what I'm after
Message 20 of 23
Kent1Cooper
in reply to: Pabber
Are you sure taking the negatives out doesn't do that?  I haven't loaded it in and tried it, but I think this should work:
A,1.2,[TRACK1,ltypeshp.shx,S=.15,R=-45,X=0,Y=0],.2,[TRACK1,ltypeshp.shx,S=.15,R=-45,X=0,Y=0]
Or, consider equalizing the end situations by splitting the line portion around the shape parts:
A,.6,[TRACK1,ltypeshp.shx,S=.15,R=-45,X=0,Y=0],.2,[TRACK1,ltypeshp.shx,S=.15,R=-45,X=0,Y=0],.6
Kent Cooper, AIA
”Boost
