Valued Contributor
MetroVancouverDrafting
Message 1 of 11 (1,190 Views)
Plot Transparency option in PLOT dialog box
1190 Views, 10 Replies
09-11-2012 03:07 PM
Is anybody knows where else do they keep this setting?
I only have found it in Active Layout in extended dada
(entget (vlax-vla-object->ename(vla-get-activelayout (vla-get-activedocument(vlax-get-acad-object)))) '("*"))
The last pice of extended data is:
 ("PLOTTRANSPARENCY" (1071 . 0))
When i change it to 1
(setq layout(vla-get-activelayout (vla-get-activedocument(vlax-get-acad-object))))
(vla-getXdata layout "PLOTTRANSPARENCY" 'type 'data)
(vlax-safearray-fill data  '("PLOTTRANSPARENCY" 1))
(vla-setXdata layout  type data)
it stays there (extended data), but the setting in Plot dialog box doesn't change!!! And it still prints no transparency.
It takes to save the drawing and reopen it again to see the change.
Where else could it be??
The command -PLOT does not have this setting as well, so my options back to VBA or Lisp, but HOW??
Active Contributor
kefer.kb
Message 2 of 11 (1,177 Views)
Re: Plot Transparency option in PLOT dialog box
09-11-2012 11:40 PM in reply to: MetroVancouverDrafting
take a look to acad-system-variable PLOTTRANSPARENCYOVERRIDE.
Maybe this would be a easier way and helpful for you.
kind regards,
Franz
www.gfm.at
Valued Contributor
Message 3 of 11 (1,163 Views)
09-12-2012 07:37 AM in reply to: kefer.kb
This variable is ACAD depended, it is not stored in the drawing and makes changes in all opened drawings. Additionally it overrides setting of all layouts.
Active Contributor
kefer.kb
Message 4 of 11 (1,147 Views)
09-13-2012 01:01 AM in reply to: MetroVancouverDrafting
OK,
now i am curious about this ...
I am not so familar with VLAX-..., but i try it with similar lisp ... and it works!
Here is my pure lisp code for testing:
Note: Entity-list elist_modellayout the applist '(-3 ("ACAD_PSEXT" ...)'  must exist.
(defun c:tplot ()
  ;----- Dictionary lesen
  (setq elist_dict (dictsearch (namedobjdict) "ACAD_LAYOUT")) (setq elist_modellayout (entget (cdr (car (cdr (member (cons 3 "Model") elist_dict)))) '("*"))) (setq list_psext (assoc -3 elist_modellayout)) ;----- Plot transparent (setq list_psext-neu (subst (list "PLOTTRANSPARENCY" '(1071 . 1)) (assoc "PLOTTRANSPARENCY" (cdr list_psext)) list_psext)) (setq elist_modellayout-neu (subst list_psext-neu list_psext elist_modellayout)) (entmod elist_modellayout-neu) ;;; ;----- Plot wieder ohne transparent Option ;;; (setq list_psext-neu (subst (list "PLOTTRANSPARENCY" '(1071 . 0)) (assoc "PLOTTRANSPARENCY" (cdr list_psext)) list_psext)) ;;; (setq elist_modellayout-neu (subst list_psext-neu list_psext elist_modellayout)) ;;; (entmod elist_modellayout-neu) );enddefun
 Last part is to set plot option back to normal (without transp.)
www.gfm.at
Valued Contributor
Message 5 of 11 (1,140 Views)
09-13-2012 07:57 AM in reply to: kefer.kb
Of course, how did i missed it , it has to be (entmod...
 (entmod(entget (vlax-vla-object->ename(vla-get-activelayout (vla-get-activedocument(vlax-get-acad-object)))) '("*")))
I guess my excuse is that I wrote in VBA first and then translated it to VLisp.
I would assume that it is a bug of VBA and automation. There is no such a thing as (entmod in VBA
Thanks kefer
Member
Alberttvz
Message 6 of 11 (1,059 Views)
10-30-2012 01:05 AM in reply to: MetroVancouverDrafting
In some layouts is no "PLOTTRANSPARENCY"...
This script (princ (entget (vlax-vla-object->ename(vla-get-activelayout (vla-get-activedocument(vlax-get-acad-object)))) '("*"))) prompts:
((-1 . <Entity name: 7ffff633e30>) (0 . LAYOUT) (5 . 15503) (102 .
{ACAD_XDICTIONARY) (360 . <Entity name: 7ffff634d30>) (102 . }) (102 .
{ACAD_REACTORS) (330 . <Entity name: 7ffff6090d0>) (102 . }) (330 . <Entity
name: 7ffff6090d0>) (100 . AcDbPlotSettings) (1 . ) (2 . Albert hp5200tn.pc3)
(4 . A3) (40 . 6.01133) (41 . 4.23334) (42 . 6.01135) (43 . 4.23334) (44 .
296.968) (45 . 419.989) (46 . -6.02718) (47 . -4.23885) (48 . -1.13687e-013)
(49 . -5.68434e-014) (140 . 420.0) (141 . 297.0) (142 . 1.0) (143 . 1.0) (70 .
694) (72 . 1) (73 . 1) (74 . 4) (7 . Dunne lijnen.ctb) (75 . 16) (147 . 1.0)
(76 . 1) (77 . 2) (78 . 150) (148 . 1.13687e-013) (149 . 5.68434e-014) (100 .
AcDbLayout) (1 . Winkel op A3) (70 . 0) (71 . 2) (10 0.00550842 0.0158482 0.0)
(11 419.994 296.984 0.0) (12 0.0 0.0 0.0) (14 -1.13687e-013 -5.68434e-014 0.0)
(15 420.0 297.0 0.0) (146 . 0.0) (13 0.0 0.0 0.0) (16 1.0 0.0 0.0) (17 0.0 1.0
0.0) (76 . 0) (330 . <Entity name: 7ffff633da0>) (331 . <Entity name:
7ffff633dc0>) (-3 (ACAD_PSEXT (1000 . Albert hp5200tn.pc3) (1000 . HP Universal
Printing PCL 6) (1000 . Renswoude) (1000 . formulemanagement_hp5200tn) (1070 .
0))))
My script doesn't work!!!:
(defun tplot ()
  (vl-load-com)
  (setq elist_modellayout (entget (vlax-vla-object->ename(vla-get-activelayout (vla-get-activedocument(vlax-get-acad-object)))) '("*")))
  (if (/= (assoc "PLOTTRANSPARENCY" (cdr (assoc -3 elist_modellayout))) nil)
    (progn
 (setq list_psext-neu (append (list -3) (list (assoc "ACAD_PSEXT" (cdr (assoc -3 elist_modellayout)))) (list (list "PLOTTRANSPARENCY" '(1071 . 1))) ))
Member
Alberttvz
Message 7 of 11 (1,018 Views)
11-09-2012 04:12 AM in reply to: MetroVancouverDrafting
I’m searching for a lisp that turns on the plottransparency in all my layouts. Note: in some of my layout tabs is no ("PLOTTRANSPARENCY"  (1071 . 0)). How do i modify the definition data of a layout with entmod?
Can i change the definition data of a layout from:
   (-1 . <Entity name: 7fffea60d20>)
   (0 . "LAYOUT")
   (331 . <Entity name: 7fffea60df0>)
   (-3
      ("ACAD_PSEXT"
         (1000 . "Microsoft XPS Document Writer")
         (1000 . "XPSPort:")
         (1000 . "")
         (1070 . 0)
To: ???
   (0 . "LAYOUT")
   (-3
      ("ACAD_PSEXT"
         (1000 . "XPSPort:")
         (1000 . "")
         (1070 . 0)
      ("PLOTTRANSPARENCY"  (1071 . 1))
I think the lisp is something like this:
(defun tplot ()
  (vl-load-com)
    (progn
    (progn
Valued Contributor
Message 8 of 11 (963 Views)
11-26-2012 11:31 AM in reply to: Alberttvz
I think you have forgotten the tird option, no extended data at all.
Member
Alberttvz
Message 9 of 11 (883 Views)
01-25-2013 01:08 AM in reply to: MetroVancouverDrafting
(defun tplot ()
  (princ "(TPLOT) ")
  (vl-load-com)
  (setq elist_modellayout (entget (vlax-vla-object->ename (vla-get-activelayout (vla-get-activedocument(vlax-get-acad-object)))) '("*")))
    (progn
        '("PLOTTRANSPARENCY" (1071 . 1))
        list_psext
    (progn
        (list -3 (cadr list_psext) '("PLOTTRANSPARENCY" (1071 . 1)))
        (list -3 (cadr list_psext))
        elist_modellayout
(Defun c:pp ()
  (if (not (tplot))
    (prompt "WARNING: PLOTTRANPARANCY NOT SET")
I can not get it working... In some drawings i can not set de plottranparency with lisp!! Who can help?
Valued Contributor
Message 10 of 11 (857 Views)
01-29-2013 09:53 AM in reply to: MetroVancouverDrafting
Well, i couldn't make it any simpler. You don't have to check if the "PLOTTRANSPARENCY" is there, just dump it in.
;;; arg1 - any layout
;;; arg2 - torn on/off 0 or 1
;;; return - Extended Entity Data
;;; call - (LayoutTransparensy (vla-get-activelayout (vla-get-activedocument(vlax-get-acad-object))) 1)
(defun LayoutTransparensy (layout ON / xType xData )
  (setq xData (vlax-make-safearray vlax-vbVariant '(0 . 1)))
  (setq xType (vlax-make-safearray vlax-vbInteger '(0 . 1)))
  (vlax-safearray-fill xData (list(vlax-make-variant "PLOTTRANSPARENCY")(vlax-make-variant ON)))
  (vlax-safearray-fill xType (list 1001 1071))
  (vla-setXdata layout  xType xData)
  (entmod(entget (vlax-vla-object->ename layout) '("*")))
