IMHO you can not do that, at least not with VBA and/or VLISP. What you want
to do is within, in the "middle" of a command, while the only reactors
available for linking to a command are :vlr-commandWillStart and
:vlrcommandEnded, :vlr-commandCancelled and :vlr-commandFailed.
HTH,
Constantin
a écrit dans le message de news: 5511711@discussion.autodesk.com...
We would like to put a watermark diagonally across the resultant plot, but
adding the watermark prior to the plot dialog box appearing is not really
suitable as the user may pick a window to plot for example that may miss the
watermark.
Essentially we would require the watermark across any type of plot, not just
of the whole drawing/current page setup
I have made a customised simplified plot dialog that either plots the
current display, current page setup or allows user to define a window, but
would like to utilise the plot preview via the PREVIEW command, but this
appears to only show the plot as defined by the page setup, so I cannot
display a preview if the user picks a window.
So, I thought I might ask the following in hope against hope that it may be
possible, before continuing with a customised version
Is there anyway possible from the plot dialog box, after pressing OK, to
deal with the plot settings and do something like add text prior to the plot
being actually plotted.
Even something cheap and nasty like selecting OK but not actually sending
the plot, getting the settings from what would now be the previous plot,
then using those settings to set the watermark and then issue another plot
command
Or if anyone has any other suggestions, I'm all ears.
Chris
