Visual LISP, AutoLISP and General Customization
Plot all layouts using Script
14 REPLIES 14
Message 1 of 15
1045 Views, 14 Replies
We use script routines for all our printing. Is there a way of selecting all of the layouts on a drawing using script so that they can be printed.
Thanks in advance.
John
14 REPLIES 14
Message 2 of 15
Isn't there a check box in the plot dialog to plot
all layouts?
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
We
in advance.
John
Message 3 of 15
That doesn't help when you are using a script. Script files are all
command line.
-Jason
Brent Upton wrote:
> Isn't there a check box in the plot dialog to plot all layouts?
> JohnAlex wrote in message
> news:f05d048.-1@WebX.maYIadrTaRb...
> Thanks in advance.
> John
Message 4 of 15
John:
How about just copying and pasting the whole mess
to the end of the file and changing the Layout part of the script for each
layout.  I do that in my sets since it seems every sheet requires some
goofy personal set up items.
Or, could one select more than one layout in that
place?  I don't know. . One may
;;example below
 -PLOT
YES
;Following is layout selected.
L-1-LP1
HP
DeskJet 1220C Printer
Tabloid (11 x 17 in.)
Inches
etc.
Good luck, let us know out here in cyber space what
you find.
Matt Fridell
saladays@gwtc.net
We
in advance.
John
Message 5 of 15
Possible strategy
1.  Make sure prior to plotting that you have used pagesetup on each
layout to get the settings right.  This simplifies each plot task.
2.  Have the script call the following function
;Function to plot all tabs in a drawing
;To work correctly, each tab
must have had PAGESETUP performed prior to
;calling plotalltab
;To plot
all layouts including model space (plotalltab t)
;To plot just paperspace
layouts (plotall nil)
(defun plotalltab ( model / n l) ;DC Broad 6-20-01  For A2K
(setq l (layoutlist))
  (setq l (if model (cons "model" l) l))
(foreach n l
   (command "-plot" "yes" n )
;and adapting some code posted earlier today to allow for a variable number of
returns
  (while (= (logand (getvar "CMDACTIVE") 1)
1)
    (command "") ;pagesetup must have been performed
or this is pot luck.
  ) ;_ end while
);end foreach
);end
plotalltab
Hope that helps.
We
in advance.
John
Message 6 of 15
How about this in your script:
(foreach tab (vl-remove "Model" (layoutlist))
(setvar "ctab" tab)
(command "-plot" etc. etc...)
Eric S.
eschneider@jensenprecast.com
Message 7 of 15
Don't think you need vl-remove. Since (layoutlist) doesn't include "model"
in the list but you pointed out a major flaw in mine. OOPS! A revision
follows.
;To work correctly, each tab must have had PAGESETUP performed prior to
;calling plotalltab
;To plot all layouts including model space (plotalltab t)
;To plot just paperspace layouts (plotall nil)
(foreach n l
(setvar "ctab" n) ;oops this was forgotten in first post.
number of returns
(while (= (logand (getvar "CMDACTIVE") 1) 1)
(command "") ;pagesetup must have been performed or this is pot luck.
) ;_ end while
);end foreach
);end plotalltab
Thanks for spotting it Eric.
Doug Broad
"Eric S." wrote in message
news:1009A3770590A81D830C4260B6F245E3@in.WebX.maYIadrTaRb...
> (setvar "ctab" tab)
> Regards,
> Eric S.
Message 8 of 15
(layoutlist) _may_ return "Model" at times. It is a noted bug (at least here
in the ng).
http://www.acadx.com
"Doug Broad" wrote in message
news:FD033FE0BF2E45265B71820CAB101DA8@in.WebX.maYIadrTaRb...
| follows.
Message 9 of 15
Thanks for correcting me. I hadn't learned of that bug. Still new to
monitoring this NG. I tested (layoulist) several times last night and
today and during those tests it did not return "model." Wish the "noted"
bugs were a little more accessible.
"R. Robert Bell" wrote in message
news:99DE9DFDB1C4B82FC558275699E09D53@in.WebX.maYIadrTaRb...
here
> in the ng).
Message 10 of 15
It's quite alright. They may have even fixed it by A2k2.
news:CF835FB50DDAD2906B8C36ADB1783965@in.WebX.maYIadrTaRb...
| here
| > in the ng).
Message 11 of 15
Thank you everybody for the help.
I'll play around with these. Good thing is that I can probaly use these for other commands to do with the layouts. Import pagesetups using -psetupin etc.
P.S. What will I do about AutoCAD LT
Message 12 of 15
Dump it, and get a real environment to program in, BwaHaHa!
"JohnAlex" wrote in message
news:f05d048.9@WebX.maYIadrTaRb...
etc.
| Thanks
Message 13 of 15
I second that.
news:28F2246A2D208051416AC79C6D284301@in.WebX.maYIadrTaRb...
Message 14 of 15
Throw your arms up in dispair. :^( No VLISP interperiters available. You
could write the code in VB(a), but that's a different news group. ;^)
Eric S.
Message 15 of 15
> in the ng).
Haven't tested this in a recent MDT version but in MDT4.0 when starting a
new drawing "from scratch" or using a template (don't recall which),
this would then show the model tab with (layoutlist).
Sincerely,
Darren J. Young
Minnesota CADWorks, Inc.
P.O. Box 7293
Saint Cloud, Minnesota 56302-7293
Phone: (320) 654-9053
WWW: http://www.mcwi.com
”Boost
